little cpu knowledge, need help building first cpu
tp101
I have very little knowledge of pc hardware and components, but i have my mind set on building one. i need help from someone who is willing to help walk me through the process. i realize it may take awhile due to my lack of skill/knowledge but am willing to spend the time learning.
im going to be using it for gaming/movies. although the gaming end does not need to be top of the line i tend to have 1-2 games on my pc at once.also i am planing on doing it slowly as far as purchasing hardware, due to income. i was planning on taking a couple months to carefully learn about components and what hardware is rigth and buy them as i go.
Just so you know:
CPU = Central Processing Unit. This refers to your processor, not the whole computer. If you need a short acronym, "PC" would be appropriate. :good:
np :)
So, I'm assuming you're on a fairly tight budget, if you're going to be buying this in pieces? If so, your best bet is probably going to be an AMD system. Right now, their processors compete very well with Intel for the price, and the total cost of a good processor and a good motherboard will be quite a bit lower. Their current Socket AM3 platform will also last a bit longer than Intel's current platforms. (meaning, you'll be able to put the newest parts on it for longer)
That's typically how it's done, yeah. The power supply is actually the most critical part of the computer, but the motherboard determines what parts you're able to use, particularly the processor.
^ That
You have to have enough power to run all of your components, particularly the graphics card if you have a high end one. Oftentimes, the cheap units in OEM computers (Dell, HP, etc) aren't powerful enough at all. You also need a well-built, reliable unit, because if you have a cheapo PSU(power supply unit) fails, it can potentially destroy every other component in your system.
The case really depends on what size motherboard you get. There are a lot of sizes, but for your needs ATX and mATX (micro ATX) are the standard motherboard sizes. An ATX mid tower or a full tower will suit your needs just fine. As far as other qualities go Airflow is probably the most important thing to keep in mind. We can help you with picking out a good one.
Oh and welcome to the forum. :):good:
Thanks. Someone already suggested an AMD am3 processor and I was looking at the tricore. What ghz should I be looking for and which motherboard/case? Alot of help so far
