I'm paying for 50 Mbps DL and 5 Mbps UL. However, upon computer startup if I check the Local Area Connection Status the speed shows 10 Mbps. Using Speedtest.net shows the same. If I disable and then reinstate the connection the speed shows 1.0 Gbps. Speed test then shows ~56Mbps. I've tried Properties>Advanced>Speed & Duplex set to 1.0 Gbps Full Duplex (Initially was set to "Auto Negotiation"). After restart it returns back to 10 Mbps.
Is there something else I could try?
Drivers are up to date.
