My HDD is failing as we speak? urgent help required
Rerun hijackthis and place checks next to the following entries.
O4 - HKLM\..\Run: [Reminder] "C:\WINDOWS\Creator\Remind_XP.exe"
O4 - HKLM\..\Run: [Recguard] "C:\WINDOWS\SMINST\RECGUARD.EXE"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Elements 6.0\apdproxy.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKCU\..\Run: [DelayShred] "c:\PROGRA~1\mcafee\mshr\ShrCL.EXE" /P7 /q c:\DOCUME~1\owner\LOCALS~1\temp\TEMPOR~1\Content.I E5\S68H14M1.SH! c:\DOCUME~1\owner\LOCALS~1\temp\TEMPOR~1\Content.I E5\K86IFILP.SH! c:\DOCUME~1\owner\LOCALS~1\temp\TEMPOR~1\Content.S H! c:\DOCUME~1\owner\LOCALS~1\temp\TEMPOR~1.SH! c:\DOCUME~1\owner\LOCALS~1\temp\TEMPOR~1.SH!\Conte nt.SH!\S68H14M1.SH! c:\DOCUME~1\owner\LOCALS~1\temp\TEMPOR~1.SH!\Conte nt.SH! c:\DOCUME~1\owner\LOCALS~1\temp\MPROJE~1\SYSTEM~1. SH! c:\DOCUME~1\owner\LOCALS~1\temp\MPROJE~1\MPLAYE~1. SH! c:\DOCUME~1\owner\LOCALS~1\temp\MPROJE~1\FLASHP~1. SH! c:\DOCUME~1\owner\LOCALS~1\temp\MPROJE~1\FLASH6~1. SH! c:\DOCUME~1\owner\LOCALS~1\temp\MPROJE~1\FILE31~1. SH! c:\DOCUME~1\owner\LOCALS~1\temp\MPROJE~1.SH! c:\DOCUME~1\owner\LOCALS~1\temp\FRF695~1.SH! c:\DOCUME~1\owner\LOCALS~1\temp\FRC26F~1.SH! c:\DOCUME~1\owner\LOCALS~1\temp\FROMCA~4.SH! c:\DOCUME~1\owner\LOCALS~1\temp\FROMCA~3.SH! c:\DOCUME~1\owner\LOCALS~1\temp\History\History.SH ! c:\DOCUME~1\owner\LOCALS~1\temp\History.SH! c:
O9 - Extra button: (no name) - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - (no file)
Then click on fix checked at the bottom.
Yes, your system is perfectly safe now. You may email or whatever you need to do.
As far as what malware protection to use. Malwarebytes and Superantispyware are kept up to date pretty regularly especially malwarebytes. You may want to think about buying the paid version of the software so that it actively scans your system all the time. The infections that are out today are mainly malware infections and not the traditional virus that there was years ago. You may want to install either the free versions of AVAST or Microsoft Security Essentials as your virus/malware scanner.
Hey johnb35! I have spent spent most of my day reading downloading and following your detailed instructions. I am not computer savvy by any means, but I must admit you are really good!!! I have 3 sets of logs; the combofix,fresh hijack and mbam. Would you mind taking a look @ them? I'm not sure what I should do @this point. FYI I'm about 90% back to restoration. Thanks again for your previous posts!
I already replied to your other post here.
http://www.computerforum.com/194686...kealert-virus-something-else.html#post1625493
HI JohnB35, I see im not the onlyone to request your help, but AJSGuns's description matches exactly what my pc problem is. I did as you said and downloaded malwarebytes and placed these results below. I then re-did the scan afterwards and it said I had no infections. At first my desktop was missing a background and the my computer and recycle bin icon, the start menu turned old school, and there was nothing in recently viewed etc. Since completing scan and rebooting (because malwarebytes told me to) I have no desktop icons other than my latest text file scan. Also noticed my e drive shows total space and free space but when I click into it it says empty folder. Please can you help?
Malwarebytes' Anti-Malware 1.50.1.1100
www.malwarebytes.org
Database version: 6465
Windows 6.0.6002 Service Pack 2
Internet Explorer 9.0.8112.16421
28/04/2011 21:06:37
mbam-log-2011-04-28 (21-06-37).txt
Scan type: Quick scan
Objects scanned: 265096
Time elapsed: 24 minute(s), 58 second(s)
Memory Processes Infected: 2
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 1
Registry Data Items Infected: 0
Folders Infected: 1
Files Infected: 13
c:\programdata\awvrvgtrjn.exe (Trojan.FakeAlert) -> 5028 -> Unloaded process successfully.
c:\programdata\38395656.exe (Trojan.FakeAlert) -> 6068 -> Unloaded process successfully.
(No malicious items detected)
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\awVRVgtrjn (Trojan.FakeAlert) -> Value: awVRVgtrjn -> Quarantined and deleted successfully.
Folders Infected:
c:\Users\Daniel\AppData\Roaming\microsoft\Windows\start menu\Programs\windows recovery (Trojan.FakeAV) -> Quarantined and deleted successfully.
Files Infected:
c:\programdata\awvrvgtrjn.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\programdata\38395656.exe (Trojan.FakeAlert) -> Delete on reboot.
c:\Users\Daniel\AppData\Local\Temp\adobe_flash_player.exe (Trojan.Agent) -> Quarantined and deleted successfully.
c:\Windows\Temp\~osCF02.tmp\rlvknlg.exe (Adware.RelevantKnowledge) -> Quarantined and deleted successfully.
c:\Windows\Temp\~osCF02.tmp\rlxf.dll (Adware.RelevantKnowledge) -> Quarantined and deleted successfully.
c:\Windows\Temp\~osCF02.tmp\rlxg.dll (Adware.RelevantKnowledge) -> Quarantined and deleted successfully.
c:\Windows\Temp\~osDA1A.tmp\rlvknlg.exe (Adware.RelevantKnowledge) -> Quarantined and deleted successfully.
c:\Users\Daniel\downloads\setupcasino_802619_en.exe (PUP.Casino) -> Quarantined and deleted successfully.
c:\Users\Daniel\downloads\VLCSetup.exe (Adware.Hotbar) -> Quarantined and deleted successfully.
c:\Users\Daniel\local settings\temporary internet files\Content.IE5\9SV7437U\readme[1].exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\Daniel\Desktop\windows recovery.lnk (Trojan.FakeAV) -> Quarantined and deleted successfully.
c:\Users\Daniel\AppData\Roaming\microsoft\Windows\start menu\Programs\windows recovery\uninstall windows recovery.lnk (Trojan.FakeAV) -> Quarantined and deleted successfully.
c:\Users\Daniel\AppData\Roaming\microsoft\Windows\start menu\Programs\windows recovery\windows recovery.lnk (Trojan.FakeAV) -> Quarantined and deleted successfully.
I was also shocked it said I had 13 infected files. I used my credit card today online, I had my cv on my desktop, logged in and and out of email accounts etc. What course of action should I take, would it be necessary to notify my bank etc? As the following scan reported no errors does that mean my pc is fixed? Other than hard drive not showing my files :-(
I also did the hijackthis report and included it below. To complete and save I had to log in on safe mode, when it was logging in safemode my original desktop full of icons briefly appeared before disappearing again? Anyways the log is below, your help would be most appreciated!
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 22:02:05, on 28/04/2011
Platform: Windows Vista SP2 (WinNT 6.00.1906)
MSIE: Internet Explorer v9.00 (9.00.8112.16421)
Boot mode: Safe mode
Running processes:
C:\Windows\Explorer.EXE
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://uk.msn.com/?ocid=OIE9HP
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Internet Explorer, optimized for Bing and MSN
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
R3 - URLSearchHook: (no name) - {A3BC75A2-1F87-4686-AA43-5347D756017C} - (no file)
R3 - URLSearchHook: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTor0.dll
R3 - URLSearchHook: Zynga Toolbar - {7b13ec3e-999a-4b70-b9cb-2617b8323822} - C:\Program Files\Zynga\tbZyn1.dll
R3 - URLSearchHook: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O1 - Hosts: ::1 localhost
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: McAfee Phishing Filter - {27B4851A-3207-45A2-B947-BE8AFE6163AB} - c:\progra~1\mcafee\msk\mskapbho.dll
O2 - BHO: Zynga Toolbar - {7b13ec3e-999a-4b70-b9cb-2617b8323822} - C:\Program Files\Zynga\tbZyn1.dll
O2 - BHO: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTor0.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20110425184608.dll
O2 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.6.6209.1142\swg.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: Ask Toolbar BHO - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O3 - Toolbar: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
O3 - Toolbar: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTor0.dll
O3 - Toolbar: Zynga Toolbar - {7b13ec3e-999a-4b70-b9cb-2617b8323822} - C:\Program Files\Zynga\tbZyn1.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: Ask Toolbar - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [NDSTray.exe] NDSTray.exe
O4 - HKLM\..\Run: [cfFncEnabler.exe] cfFncEnabler.exe
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [Google EULA Launcher] c:\Program Files\Google\Google EULA\GoogleEULALauncher.exe IE PA
O4 - HKLM\..\Run: [Toshiba TEMPO] C:\Program Files\Toshiba TEMPRO\Toshiba.Tempo.UI.TrayApplication.exe
O4 - HKLM\..\Run: [topi] C:\Program Files\TOSHIBA\Toshiba Online Product Information\topi.exe -startup
O4 - HKLM\..\Run: [IgfxTray] C:\Windows\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\Windows\system32\hkcmd.exe
O4 - HKLM\..\Run: [Persistence] C:\Windows\system32\igfxpers.exe
O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
O4 - HKLM\..\Run: [Skytel] Skytel.exe
O4 - HKLM\..\Run: [TPwrMain] %ProgramFiles%\TOSHIBA\Power Saver\TPwrMain.EXE
O4 - HKLM\..\Run: [HSON] %ProgramFiles%\TOSHIBA\TBS\HSON.exe
O4 - HKLM\..\Run: [SmoothView] %ProgramFiles%\Toshiba\SmoothView\SmoothView.exe
O4 - HKLM\..\Run: [00TCrdMain] %ProgramFiles%\TOSHIBA\FlashCards\TCrdMain.exe
O4 - HKLM\..\Run: [Toshiba Registration] C:\Program Files\Toshiba\Registration\ToshibaRegistration.exe
O4 - HKLM\..\Run: [Camera Assistant Software] "C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe" /start
O4 - HKLM\..\Run: [jswtrayutil] "C:\Program Files\Jumpstart\jswtrayutil.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [mcui_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKCU\..\Run: [TOSCDSPD] TOSCDSPD.EXE
O4 - HKCU\..\Run: [swg] "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [Google Update] "C:\Users\Daniel\AppData\Local\Google\Update\GoogleUpdate.exe" /c
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - .DEFAULT User Startup: TRDCReminder.lnk = C:\Program Files\TOSHIBA\TRDCReminder\TRDCReminder.exe (User 'Default user')
O4 - Startup: Dropbox.lnk = C:\Users\Daniel\AppData\Roaming\Dropbox\bin\Dropbox.exe
O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Remote Mouse Server.lnk = C:\Program Files\Remote Mouse Server\RemoteMouse.exe
O4 - Global Startup: TOSHIBA Face Recognition Watcher.lnk = C:\Program Files\Toshiba\SmartFaceV\SmartFaceVWatcher.exe
O4 - Global Startup: WinZip Quick Pick.lnk = C:\Program Files\WinZip\WZQKPICK.EXE
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Google Sidewiki... - res://C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_D183CA64F05FDD98.dll/cmsidewiki.html
O9 - Extra button: Sky - {08E730A4-FB02-45BD-A900-01E4AD8016F6} - http://www.sky.com (file missing)
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: eBay.co.uk - Buy It Sell It Love It - {76577871-04EC-495E-A12B-91F7C3600AFA} - http://rover.ebay.com/rover/1/710-44557-9400-3/4 (file missing)
O9 - Extra button: Amazon.co.uk - {8A918C1D-E123-4E36-B562-5C1519E434CE} - http://www.amazon.co.uk/exec/obidos/redirect-home?tag=Toshibaukbholink-21&site=home (file missing)
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL
O9 - Extra button: Wallpaper - {c23dd370-cb79-11d2-898a-00c04f80a47f} - C:\Program Files\Internet Explorer\Toolbar\toolbar.hta
O9 - Extra 'Tools' menuitem: &Toolbar Wallpaper - {c23dd370-cb79-11d2-898a-00c04f80a47f} - C:\Program Files\Internet Explorer\Toolbar\toolbar.hta
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O15 - Trusted Zone: http://*.mcafee.com
O18 - Protocol: dssrequest - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O20 - AppInit_DLLs: AVGRSSTX.DLL C:\PROGRA~1\GOOGLE\GOOGLE~2\GOEC62~1.DLL
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\Windows\system32\browseui.dll
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\Windows\system32\agrsmsvc.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: ConfigFree Service - TOSHIBA CORPORATION - C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
O23 - Service: Google Desktop Manager 5.9.911.3589 (GoogleDesktopManager-110309-193829) - Google - C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Jumpstart Wifi Protected Setup (jswpsapi) - Atheros Communications, Inc. - C:\Program Files\Jumpstart\jswpsapi.exe
O23 - Service: McAfee SiteAdvisor Service - McAfee, Inc. - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Personal Firewall Service (McMPFSvc) - McAfee, Inc. - C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee VirusScan Announcer (McNaiAnn) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McShield - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe
O23 - Service: McAfee Firewall Core Service (mfefire) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe
O23 - Service: McAfee Validation Trust Protection Service (mfevtp) - McAfee, Inc. - C:\Windows\system32\mfevtps.exe
O23 - Service: McAfee Anti-Spam Service (MSK80Service) - McAfee, Inc. - C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
O23 - Service: Rapport Management Service (RapportMgmtService) - Trusteer Ltd. - C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe
O23 - Service: SmartFaceVWatchSrv - Toshiba - C:\Program Files\TOSHIBA\SmartFaceV\SmartFaceVWatchSrv.exe
O23 - Service: Notebook Performance Tuning Service (TempoMonitoringService) - Toshiba Europe GmbH - C:\Program Files\Toshiba TEMPRO\TempoSVC.exe
O23 - Service: TOSHIBA Navi Support Service (TNaviSrv) - TOSHIBA Corporation - C:\Program Files\TOSHIBA\TOSHIBA DVD PLAYER\TNaviSrv.exe
O23 - Service: TOSHIBA Optical Disc Drive Service (TODDSrv) - TOSHIBA Corporation - C:\Windows\system32\TODDSrv.exe
O23 - Service: TOSHIBA Power Saver (TosCoSrv) - TOSHIBA Corporation - C:\Program Files\TOSHIBA\Power Saver\TosCoSrv.exe
O23 - Service: TOSHIBA SMART Log Service - TOSHIBA Corporation - C:\Program Files\TOSHIBA\SMARTLogService\TosIPCSrv.exe
O23 - Service: Ulead Burning Helper (UleadBurningHelper) - Ulead Systems, Inc. - C:\Program Files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
End of file - 13099 bytes
Also - sorry if I sound stupid, but so you know i searched the computer for some files I know were on my desktop, such as my cv and a music file, and they do not show up? Searched in start menu search box.
Please disable mcafee before running the following program.
Download and Run ComboFix
If you already have Combofix, please delete this copy and download it again as it's being updated regularly.
Note: Do not mouseclick combofix's window whilst it's running. That may cause it to stall
Combofix should never take more that 20 minutes including the reboot if malware is detected.
In your next reply please post:
  • The ComboFix log
  • A fresh HiJackThis log
  • An update on how your computer is running
Hi John thanks for getting back to me. I think I disabled everything in mcafee but noticed it mentioned mcafee in the combofix report below.
How my computers doing now- It now displays every icon I had on the desktop but no recycle bin or my computer icon. It now opens the hard drive it said was empty which is great. My background is white, the start bar doesnt expand in the bottom right corner, I can see the little icon to say pc is charging and connected to internet but it had loads of icons there, some which came with computer and some like mcafee which seem to have disappeared but i think are all still on start menu.
ComboFix 11-04-28.01 - Daniel 28/04/2011 23:30:36.1.2 - x86
Running from: c:\users\Daniel\Downloads\ComboFix.exe
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
c:\users\Daniel\GoToAssistDownloadHelper.exe
((((((((((((((((((((((((( Files Created from 2011-03-28 to 2011-04-28 )))))))))))))))))))))))))))))))
2011-04-28 22:43 . 2011-04-28 22:43 -------- d-----w- c:\users\Default\AppData\Local\temp
2011-04-28 20:48 . 2011-04-28 20:48 388096 ----a-r- c:\users\Daniel\AppData\Roaming\Microsoft\Installer\{45A66726-69BC-466B-A7A4-12FCBA4883D7}\HiJackThis.exe
2011-04-28 20:48 . 2011-04-28 20:48 -------- d-----w- c:\program files\Trend Micro
2011-04-28 19:27 . 2011-04-28 19:27 -------- d--h--w- c:\users\Daniel\AppData\Roaming\Malwarebytes
2011-04-28 19:27 . 2010-12-20 17:09 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2011-04-28 19:27 . 2011-04-28 19:27 -------- d--h--w- c:\programdata\Malwarebytes
2011-04-28 19:27 . 2011-04-28 19:27 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2011-04-28 19:27 . 2010-12-20 17:08 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
2011-04-28 19:02 . 2011-04-28 19:02 -------- d--h--w- c:\users\Daniel\AppData\Local\{0D557F21-0FFC-4F91-9B50-CAB79F60D4E0}
2011-04-28 15:56 . 2011-04-28 15:56 784136 ---ha-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight\SpotlightResources.dll
2011-04-25 17:46 . 2010-10-13 21:28 9344 ----a-w- c:\windows\system32\drivers\mfeclnk.sys
2011-04-25 17:46 . 2010-10-13 21:28 24376 ----a-w- c:\program files\Mozilla Firefox\components\Scriptff.dll
2011-04-25 17:45 . 2010-10-13 21:28 141792 ----a-w- c:\windows\system32\mfevtps.exe
2011-04-25 17:45 . 2010-10-13 21:28 95600 ----a-w- c:\windows\system32\drivers\mfeapfk.sys
2011-04-25 17:45 . 2010-10-13 21:28 84264 ----a-w- c:\windows\system32\drivers\mferkdet.sys
2011-04-25 17:45 . 2010-10-13 21:28 64304 ----a-w- c:\windows\system32\drivers\mfenlfk.sys
2011-04-25 17:45 . 2010-10-13 21:28 55840 ----a-w- c:\windows\system32\drivers\cfwids.sys
2011-04-25 17:45 . 2010-10-13 21:28 313288 ----a-w- c:\windows\system32\drivers\mfefirek.sys
2011-04-25 17:45 . 2010-10-13 21:28 164840 ----a-w- c:\windows\system32\drivers\mfewfpk.sys
2011-04-25 17:39 . 2011-04-25 17:39 -------- d--h--w- c:\users\Daniel\AppData\Local\{DDDF88E5-3148-4AD3-AC87-3677477D4A2A}
2011-04-21 17:10 . 2011-04-21 17:10 -------- d--h--w- c:\users\Daniel\AppData\Local\{A79D7121-4214-41A6-BA0C-D23E0DD1CD54}
2011-04-19 16:43 . 2011-04-19 16:43 -------- d--h--w- c:\users\Daniel\AppData\Local\{F37C78FF-C9AF-4395-B36E-C9682A859F01}
2011-04-18 16:39 . 2011-04-18 16:39 -------- d--h--w- c:\users\Daniel\AppData\Local\{B43405BA-E111-4FC3-B5EB-F4D44435E5D2}
2011-04-17 22:21 . 2011-04-17 22:21 -------- d--h--w- c:\programdata\TorrentEasy
2011-04-17 22:17 . 2011-04-17 22:17 -------- d--h--w- c:\users\Daniel\AppData\Local\{AD31C182-7E52-4D3F-94DF-A4E07C4003CA}
2011-04-16 11:39 . 2011-04-16 11:39 -------- d--h--w- c:\users\Daniel\AppData\Local\Trusteer
2011-04-15 21:16 . 2011-04-15 21:16 -------- d--h--w- c:\users\Daniel\AppData\Local\{037999AA-78E7-4616-8154-6D2596033D07}
2011-04-15 21:01 . 2011-02-16 14:02 292864 ----a-w- c:\windows\system32\atmfd.dll
2011-04-15 21:01 . 2011-02-16 16:16 34304 ----a-w- c:\windows\system32\atmlib.dll
2011-04-15 21:01 . 2011-02-22 13:24 213504 ----a-w- c:\windows\system32\drivers\mrxsmb10.sys
2011-04-15 21:01 . 2011-02-22 13:24 79360 ----a-w- c:\windows\system32\drivers\mrxsmb20.sys
2011-04-15 21:01 . 2011-02-22 13:23 106496 ----a-w- c:\windows\system32\drivers\mrxsmb.sys
2011-04-15 21:01 . 2011-02-22 13:23 69632 ----a-w- c:\windows\system32\drivers\bowser.sys
2011-04-15 21:00 . 2011-03-10 17:03 1162240 ----a-w- c:\windows\system32\mfc42u.dll
2011-04-15 21:00 . 2011-03-10 17:03 1136640 ----a-w- c:\windows\system32\mfc42.dll
2011-04-15 21:00 . 2011-02-18 14:03 305152 ----a-w- c:\windows\system32\drivers\srv.sys
2011-04-15 21:00 . 2011-02-18 14:03 146432 ----a-w- c:\windows\system32\drivers\srv2.sys
2011-04-15 21:00 . 2011-02-18 14:03 102400 ----a-w- c:\windows\system32\drivers\srvnet.sys
2011-04-15 21:00 . 2011-03-02 15:44 86528 ----a-w- c:\windows\system32\dnsrslvr.dll
2011-04-15 21:00 . 2009-05-04 09:59 25088 ----a-w- c:\windows\system32\dnscacheugc.exe
2011-04-15 20:59 . 2011-03-03 13:25 2041856 ----a-w- c:\windows\system32\win32k.sys
2011-04-15 20:59 . 2011-03-03 15:42 739328 ----a-w- c:\windows\system32\inetcomm.dll
2011-04-15 20:59 . 2011-03-03 10:50 2409784 ----a-w- c:\program files\Windows Mail\OESpamFilter.dat
2011-04-14 16:46 . 2011-04-14 16:46 -------- d--h--w- c:\users\Daniel\AppData\Local\{58945FFF-F4FE-40A5-8EE7-0E315FBBDC1B}
2011-04-12 15:39 . 2011-04-12 15:39 -------- d--h--w- c:\users\Daniel\AppData\Local\{28E389D7-96A8-4747-B865-DB2E70BF0AEA}
2011-04-08 09:17 . 2011-04-08 09:17 53816 ----a-w- c:\windows\system32\drivers\RapportKELL.sys
2011-04-05 17:01 . 2011-04-05 17:01 -------- d--h--w- c:\users\Daniel\AppData\Local\{AD7C9BDE-F043-4629-BC1A-20FFBEBF7BC1}
2011-04-03 15:20 . 2011-04-03 15:25 -------- d--h--w- c:\users\Daniel\AppData\Roaming\Garden Planner
2011-04-03 15:20 . 2011-04-03 15:20 -------- d--h--w- c:\programdata\Garden Planner
2011-04-03 15:20 . 2011-04-03 15:20 -------- d-----w- c:\program files\Garden Planner
2011-04-03 15:09 . 2011-04-03 15:09 -------- d--h--w- c:\users\Daniel\AppData\Local\{5DA92F50-ECF1-4A77-8392-995E70DB13AC}
2011-04-01 16:32 . 2011-04-01 16:32 -------- d--h--w- c:\users\Daniel\AppData\Local\{4C35971C-B476-4016-805B-7B48060F7780}
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2011-03-17 21:11 . 2011-03-17 21:11 161792 ----a-w- c:\windows\system32\msls31.dll
2011-03-17 21:11 . 2011-03-17 21:11 1126912 ----a-w- c:\windows\system32\wininet.dll
2011-03-17 21:11 . 2011-03-17 21:11 74752 ----a-w- c:\windows\system32\RegisterIEPKEYs.exe
2011-03-17 21:11 . 2011-03-17 21:11 86528 ----a-w- c:\windows\system32\iesysprep.dll
2011-03-17 21:11 . 2011-03-17 21:11 76800 ----a-w- c:\windows\system32\SetIEInstalledDate.exe
2011-03-17 21:11 . 2011-03-17 21:11 48640 ----a-w- c:\windows\system32\mshtmler.dll
2011-03-17 21:11 . 2011-03-17 21:11 63488 ----a-w- c:\windows\system32\tdc.ocx
2011-03-17 21:11 . 2011-03-17 21:11 367104 ----a-w- c:\windows\system32\html.iec
2011-03-17 21:11 . 2011-03-17 21:11 74752 ----a-w- c:\windows\system32\iesetup.dll
2011-03-17 21:11 . 2011-03-17 21:11 23552 ----a-w- c:\windows\system32\licmgr10.dll
2011-03-17 21:11 . 2011-03-17 21:11 1427456 ----a-w- c:\windows\system32\inetcpl.cpl
2011-03-17 21:11 . 2011-03-17 21:11 152064 ----a-w- c:\windows\system32\wextract.exe
2011-03-17 21:11 . 2011-03-17 21:11 150528 ----a-w- c:\windows\system32\iexpress.exe
2011-03-17 21:11 . 2011-03-17 21:11 420864 ----a-w- c:\windows\system32\vbscript.dll
2011-03-17 21:11 . 2011-03-17 21:11 2382848 ----a-w- c:\windows\system32\mshtml.tlb
2011-03-17 21:11 . 2011-03-17 21:11 142848 ----a-w- c:\windows\system32\ieUnatt.exe
2011-03-17 21:11 . 2011-03-17 21:11 1797632 ----a-w- c:\windows\system32\jscript9.dll
2011-03-17 21:11 . 2011-03-17 21:11 11776 ----a-w- c:\windows\system32\mshta.exe
2011-03-17 21:11 . 2011-03-17 21:11 101888 ----a-w- c:\windows\system32\admparse.dll
2011-03-17 21:11 . 2011-03-17 21:11 35840 ----a-w- c:\windows\system32\imgutil.dll
2011-03-17 21:11 . 2011-03-17 21:11 110592 ----a-w- c:\windows\system32\IEAdvpack.dll
2011-03-13 13:20 . 2010-06-24 11:33 18328 ----a-w- c:\programdata\Microsoft\IdentityCRL\production\ppcrlconfig600.dll
2011-02-22 14:13 . 2011-03-22 19:52 288768 ----a-w- c:\windows\system32\XpsGdiConverter.dll
2011-02-22 13:33 . 2011-03-22 19:52 1068544 ----a-w- c:\windows\system32\DWrite.dll
2011-02-22 13:33 . 2011-03-22 19:52 797696 ----a-w- c:\windows\system32\FntCache.dll
2011-02-02 21:40 . 2010-07-12 22:03 472808 ----a-w- c:\windows\system32\deployJava1.dll
2010-10-13 21:28 . 2011-04-25 17:46 24376 ----a-w- c:\program files\mozilla firefox\components\Scriptff.dll
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{7c5c0f58-e061-457d-9033-77307f5ed00c}"= "c:\program files\TorrentMan\tbTor0.dll" [2008-05-21 1526296]
"{7b13ec3e-999a-4b70-b9cb-2617b8323822}"= "c:\program files\Zynga\tbZyn1.dll" [2010-09-23 2734688]
[HKEY_CLASSES_ROOT\clsid\{7c5c0f58-e061-457d-9033-77307f5ed00c}]
[HKEY_CLASSES_ROOT\clsid\{7b13ec3e-999a-4b70-b9cb-2617b8323822}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{7b13ec3e-999a-4b70-b9cb-2617b8323822}]
2010-09-23 18:13 2734688 ----a-w- c:\program files\Zynga\tbZyn1.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{7c5c0f58-e061-457d-9033-77307f5ed00c}]
2008-05-21 00:43 1526296 ----a-w- c:\program files\TorrentMan\tbTor0.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{D4027C7F-154A-4066-A1AD-4243D8127440}]
2011-02-01 19:17 1487240 ----a-w- c:\program files\Ask.com\GenericAskToolbar.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
"{D4027C7F-154A-4066-A1AD-4243D8127440}"= "c:\program files\Ask.com\GenericAskToolbar.dll" [2011-02-01 1487240]
[HKEY_CLASSES_ROOT\clsid\{d4027c7f-154a-4066-a1ad-4243d8127440}]
[HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd.1]
[HKEY_CLASSES_ROOT\TypeLib\{2996F0E7-292B-4CAE-893F-47B8B1C05B56}]
[HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd]
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\Webbrowser]
"{7C5C0F58-E061-457D-9033-77307F5ED00C}"= "c:\program files\TorrentMan\tbTor0.dll" [2008-05-21 1526296]
"{7B13EC3E-999A-4B70-B9CB-2617B8323822}"= "c:\program files\Zynga\tbZyn1.dll" [2010-09-23 2734688]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\DropboxExt1]
@="{FB314ED9-A251-47B7-93E1-CDD82E34AF8B}"
[HKEY_CLASSES_ROOT\CLSID\{FB314ED9-A251-47B7-93E1-CDD82E34AF8B}]
2010-10-06 23:36 94208 ---ha-w- c:\users\Daniel\AppData\Roaming\Dropbox\bin\DropboxExt.14.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\DropboxExt2]
@="{FB314EDA-A251-47B7-93E1-CDD82E34AF8B}"
[HKEY_CLASSES_ROOT\CLSID\{FB314EDA-A251-47B7-93E1-CDD82E34AF8B}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\DropboxExt3]
@="{FB314EDB-A251-47B7-93E1-CDD82E34AF8B}"
[HKEY_CLASSES_ROOT\CLSID\{FB314EDB-A251-47B7-93E1-CDD82E34AF8B}]
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-08-07 68856]
"msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2010-11-10 4240760]
"ehTray.exe"="c:\windows\ehome\ehTray.exe" [2008-01-21 125952]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2008-01-21 202240]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2008-08-14 1348904]
"NDSTray.exe"="NDSTray.exe" [BU]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2009-11-16 30192]
"Google EULA Launcher"="c:\program files\Google\Google EULA\GoogleEULALauncher.exe" [2008-05-28 20480]
"Toshiba TEMPO"="c:\program files\Toshiba TEMPRO\Toshiba.Tempo.UI.TrayApplication.exe" [2008-04-24 103824]
"topi"="c:\program files\TOSHIBA\Toshiba Online Product Information\topi.exe" [2007-07-10 581632]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2008-06-25 150040]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2008-06-25 170520]
"Persistence"="c:\windows\system32\igfxpers.exe" [2008-06-25 145944]
"RtHDVCpl"="RtHDVCpl.exe" [2008-04-08 6037504]
"Skytel"="Skytel.exe" [2007-11-20 1826816]
"Toshiba Registration"="c:\program files\Toshiba\Registration\ToshibaRegistration.exe" [2008-01-11 574864]
"Camera Assistant Software"="c:\program files\Camera Assistant Software for Toshiba\traybar.exe" [2008-09-26 417792]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-10-15 39792]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe" [2010-12-14 47904]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2010-11-29 421888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-12-13 421160]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-10-29 249064]
"mcui_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2011-01-17 1193848]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
"AppInit_DLLs"=c:\progra~1\Google\GOOGLE~2\GoogleDesktopNetwork3.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
"aux"=wdmaud.drv
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS]
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2010-01-31 135664]
R3 ASPI;Advanced SCSI Programming Interface Driver;c:\windows\System32\DRIVERS\ASPI32.sys [2002-07-17 84832]
R3 GoogleDesktopManager-110309-193829;Google Desktop Manager 5.9.911.3589;c:\program files\Google\Google Desktop Search\GoogleDesktop.exe [2009-11-16 30192]
R3 gupdatem;Google Update Service (gupdatem);c:\program files\Google\Update\GoogleUpdate.exe [2010-01-31 135664]
R3 jswpsapi;Jumpstart Wifi Protected Setup;c:\program files\Jumpstart\jswpsapi.exe [2008-04-16 954368]
R3 mferkdet;McAfee Inc. mferkdet;c:\windows\system32\drivers\mferkdet.sys [2010-10-13 84264]
R3 osppsvc;Office Software Protection Platform;c:\program files\Common Files\Microsoft Shared\OfficeSoftwareProtectionPlatform\OSPPSVC.EXE [2010-01-09 4640000]
R3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [2010-03-18 753504]
S0 RapportKELL;RapportKELL;c:\windows\System32\Drivers\RapportKELL.sys [2011-04-08 53816]
S1 jswpslwf;JumpStart Wireless Filter Driver;c:\windows\system32\DRIVERS\jswpslwf.sys [2008-04-28 20384]
S1 mfenlfk;McAfee NDIS Light Filter;c:\windows\system32\DRIVERS\mfenlfk.sys [2010-10-13 64304]
S1 mfewfpk;McAfee Inc. mfewfpk;c:\windows\system32\drivers\mfewfpk.sys [2010-10-13 164840]
S1 RapportCerberus_25973;RapportCerberus_25973;c:\programdata\Trusteer\Rapport\store\exts\RapportCerberus\25973\RapportCerberus_25973.sys [2011-04-14 57144]
S1 RapportEI;RapportEI;c:\program files\Trusteer\Rapport\bin\RapportEI.sys [2011-04-08 66360]
S1 RapportPG;RapportPG;c:\program files\Trusteer\Rapport\bin\RapportPG.sys [2011-04-08 158904]
S2 ConfigFree Service;ConfigFree Service;c:\program files\TOSHIBA\ConfigFree\CFSvcs.exe [2008-04-16 40960]
S2 cvhsvc;Client Virtualization Handler;c:\program files\Common Files\Microsoft Shared\Virtualization Handler\CVHSVC.EXE [2010-02-28 821664]
S2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [2011-02-16 88176]
S2 McMPFSvc;McAfee Personal Firewall Service;c:\program files\Common Files\Mcafee\McSvcHost\McSvHost.exe [2010-03-10 271480]
S2 McNaiAnn;McAfee VirusScan Announcer;c:\program files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 271480]
S2 mfefire;McAfee Firewall Core Service;c:\program files\Common Files\McAfee\SystemCore\\mfefire.exe [2010-10-13 188136]
S2 mfevtp;McAfee Validation Trust Protection Service;c:\windows\system32\mfevtps.exe [2010-10-13 141792]
S2 RapportMgmtService;Rapport Management Service;c:\program files\Trusteer\Rapport\bin\RapportMgmtService.exe [2011-04-08 870200]
S2 sftlist;Application Virtualization Client;c:\program files\Microsoft Application Virtualization Client\sftlist.exe [2010-04-24 483688]
S2 TempoMonitoringService;Notebook Performance Tuning Service ;c:\program files\Toshiba TEMPRO\TempoSVC.exe [2008-04-24 99720]
S2 TOSHIBA SMART Log Service;TOSHIBA SMART Log Service;c:\program files\TOSHIBA\SMARTLogService\TosIPCSrv.exe [2008-02-06 126976]
S3 cfwids;McAfee Inc. cfwids;c:\windows\system32\drivers\cfwids.sys [2010-10-13 55840]
S3 FwLnk;FwLnk Driver;c:\windows\system32\DRIVERS\FwLnk.sys [2006-11-20 7168]
S3 mfefirek;McAfee Inc. mfefirek;c:\windows\system32\drivers\mfefirek.sys [2010-10-13 313288]
S3 Sftfs;Sftfs;c:\windows\system32\DRIVERS\Sftfslh.sys [2010-04-24 550760]
S3 Sftplay;Sftplay;c:\windows\system32\DRIVERS\Sftplaylh.sys [2010-04-24 195944]
S3 Sftredir;Sftredir;c:\windows\system32\DRIVERS\Sftredirlh.sys [2010-04-24 21864]
S3 Sftvol;Sftvol;c:\windows\system32\DRIVERS\Sftvollh.sys [2010-04-24 19304]
S3 sftvsa;Application Virtualization Service Agent;c:\program files\Microsoft Application Virtualization Client\sftvsa.exe [2010-04-24 209768]
S3 SmartFaceVWatchSrv;SmartFaceVWatchSrv;c:\program files\TOSHIBA\SmartFaceV\SmartFaceVWatchSrv.exe [2008-08-25 77824]
--- Other Services/Drivers In Memory ---
*Deregistered* - mfeavfk01
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
LocalServiceAndNoImpersonation REG_MULTI_SZ FontCache
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{c23dd370-cb79-11d2-898a-00c04f80a47f}]
2011-03-17 21:11 114176 ----a-w- c:\windows\System32\advpack.dll
Contents of the 'Scheduled Tasks' folder
2011-04-28 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-01-31 16:29]
2011-04-28 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2011-04-28 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-590934792-190235506-1732831347-1000Core.job
- c:\users\Daniel\AppData\Local\Google\Update\GoogleUpdate.exe [2009-10-18 16:54]
2011-04-28 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-590934792-190235506-1732831347-1000UA.job
------- Supplementary Scan -------
uStart Page = hxxp://www.google.co.uk/
mStart Page = hxxp://www.google.com/ig/redirectdomain?brand=TSEA&bmod=TSEA
uInternet Settings,ProxyOverride = *.local
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_D183CA64F05FDD98.dll/cmsidewiki.html
Trusted Zone: internet
Trusted Zone: mcafee.com
FF - ProfilePath - c:\users\Daniel\AppData\Roaming\Mozilla\Firefox\Profiles\ncro8ecg.default\
FF - prefs.js: browser.search.selectedEngine - Google
FF - prefs.js: browser.startup.homepage - hxxp://www.google.co.uk/
FF - prefs.js: keyword.URL - hxxp://uk.search.yahoo.com/search?fr=mcafee&p=
FF - prefs.js: network.proxy.type - 0
FF - Ext: Default: {972ce4c6-7e08-4474-a285-3208198ce6fd} - c:\program files\Mozilla Firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
FF - Ext: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension
FF - Ext: McAfee SiteAdvisor: {B7082FAA-CB62-4872-9106-E42DD88EDE45} - c:\program files\McAfee\SiteAdvisor
FF - Ext: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - %profile%\extensions\{20a82645-c095-46ed-80e3-08825760534b}
FF - Ext: Ask Toolbar: [email protected] - %profile%\extensions\[email protected]
- - - - ORPHANS REMOVED - - - -
URLSearchHooks-{A3BC75A2-1F87-4686-AA43-5347D756017C} - (no file)
Toolbar-{CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
WebBrowser-{CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
HKCU-Run-TOSCDSPD - TOSCDSPD.EXE
HKLM-Run-cfFncEnabler.exe - cfFncEnabler.exe
HKLM-Run-TPwrMain - %ProgramFiles%\TOSHIBA\Power Saver\TPwrMain.EXE
HKLM-Run-HSON - %ProgramFiles%\TOSHIBA\TBS\HSON.exe
HKLM-Run-SmoothView - %ProgramFiles%\Toshiba\SmoothView\SmoothView.exe
HKLM-Run-00TCrdMain - %ProgramFiles%\TOSHIBA\FlashCards\TCrdMain.exe
HKLM-Run-jswtrayutil - c:\program files\Jumpstart\jswtrayutil.exe
AddRemove-Sniper Ghost Warrior_is1 - c:\program files\City Interactive\Sniper Ghost Warrior\unins000.exe
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2011-04-28 23:44
Windows 6.0.6002 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_USERS\S-1-5-21-590934792-190235506-1732831347-1000\Software\SecuROM\!CAUTION! NEVER A OR CHANGE ANY KEY*]
@Allowed: (Read) (RestrictedCode)
"??"=hex:23,53,e5,e9,a9,11,c1,6d,9a,ae,23,84,97,8a,ef,5f,e1,cc,4c,86,72,d9,4a,
e7,dc,9b,75,10,5e,9c,39,77,0f,4d,6e,93,6f,08,9f,6b,c2,d0,cb,62,10,11,67,76,\
"??"=hex:5d,2e,bc,00,9b,07,bc,9c,34,34,87,88,c9,ab,ca,0d
[HKEY_USERS\S-1-5-21-590934792-190235506-1732831347-1000\Software\SecuROM\License information*]
"datasecu"=hex:10,9c,2b,99,76,34,f3,02,ca,0c,97,19,d1,8b,0d,f5,fa,a4,21,aa,46,
e4,67,e9,ce,51,06,07,4b,a8,35,0f,e6,15,53,d1,f0,4c,4a,d5,d8,e9,2d,6c,1f,dd,\
"rkeysecu"=hex:60,70,43,f3,da,ef,3e,d6,ef,b3,2d,9f,1f,cb,31,f1
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
@Denied: (A) (Users)
@Denied: (A) (Everyone)
@Allowed: (B 1 2 3 4 5) (S-1-5-20)
"BlindDial"=dword:00000000
"MSCurrentCountry"=dword:000000b5
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0002\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0004\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0006\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0007\AllUserSettings]
Completion time: 2011-04-28 23:54:35
ComboFix-quarantined-files.txt 2011-04-28 22:54
Pre-Run: 6,220,529,664 bytes free
Post-Run: 8,487,792,640 bytes free
- - End Of File - - 947404FE0DCEE7B3887AD388C9F22471
Scan saved at 00:07:21, on 29/04/2011
Boot mode: Normal
Running processes:
C:\Windows\system32\Dwm.exe
C:\Windows\system32\taskeng.exe
C:\Program Files\Trusteer\Rapport\bin\RapportService.exe
C:\Windows\System32\hkcmd.exe
C:\Windows\System32\igfxpers.exe
C:\Windows\RtHDVCpl.exe
C:\Program Files\TOSHIBA\Power Saver\TPwrMain.exe
C:\Program Files\TOSHIBA\SmoothView\SmoothView.exe
C:\Program Files\TOSHIBA\FlashCards\TCrdMain.exe
C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe
C:\Windows\ehome\ehtray.exe
C:\Program Files\Windows Media Player\wmpnscfg.exe
C:\Windows\system32\igfxsrvc.exe
C:\Windows\ehome\ehmsas.exe
C:\Users\Daniel\AppData\Local\Google\Chrome\Application\chrome.exe
C:\Windows\system32\igfxext.exe
C:\Program Files\Synaptics\SynTP\SynTPHelper.exe
C:\Windows\system32\wuauclt.exe
C:\Windows\explorer.exe
C:\Windows\system32\SearchFilterHost.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~2\GoogleDesktopNetwork3.dll
End of file - 13625 bytes
Please rerun hijackthis and place checks next to the following entries.
Then click on fix checked.
1. Go to Start > Run > type Notepad.exe and click OK to open Notepad.
It must be Notepad, not Wordpad.
2. Copy the text in the below code box
Code:
Folder::
Registry::
[-HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
[-HKEY_CLASSES_ROOT\clsid\{7c5c0f58-e061-457d-9033-77307f5ed00c}]
[-HKEY_CLASSES_ROOT\clsid\{7b13ec3e-999a-4b70-b9cb-2617b8323822}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{7b13ec3e-999a-4b70-b9cb-2617b8323822}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{7c5c0f58-e061-457d-9033-77307f5ed00c}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{D4027C7F-154A-4066-A1AD-4243D8127440}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
[-HKEY_CLASSES_ROOT\clsid\{d4027c7f-154a-4066-a1ad-4243d8127440}]
[-HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd.1]
[-HKEY_CLASSES_ROOT\TypeLib\{2996F0E7-292B-4CAE-893F-47B8B1C05B56}]
[-HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd]
[-HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\Webbrowser]
Reglock::
"??"=hex:23,53,e5,e9,a9,11,c1,6d,9a,ae,23,84,97,8a ,ef,5f,e1,cc,4c,86,72,d9,4a,
e7,dc,9b,75,10,5e,9c,39,77,0f,4d,6e,93,6f,08,9f,6b ,c2,d0,cb,62,10,11,67,76,\
"??"=hex:5d,2e,bc,00,9b,07,bc,9c,34,34,87,88,c9,ab ,ca,0d
"datasecu"=hex:10,9c,2b,99,76,34,f3,02,ca,0c,97,19 ,d1,8b,0d,f5,fa,a4,21,aa,46,
e4,67,e9,ce,51,06,07,4b,a8,35,0f,e6,15,53,d1,f0,4c ,4a,d5,d8,e9,2d,6c,1f,dd,\
"rkeysecu"=hex:60,70,43,f3,da,ef,3e,d6,ef,b3,2d,9f ,1f,cb,31,f1
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Cl ass\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Cl ass\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0002\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Cl ass\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0004\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Cl ass\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0006\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Cl ass\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0007\AllUserSettings]
3. Go to the Notepad window and click Edit > Paste
4. Then click File > Save
5. Name the file CFScript.txt - Save the file to your Desktop
6. Then drag the CFScript (hold the left mouse button while dragging the file) and drop it (release the left mouse button) into ComboFix.exe as you see in the screenshot below. Important: Perform this instruction carefully!
ComboFix will begin to execute, just follow the prompts.
After reboot (in case it asks to reboot), it will produce a log for you.
Post that log (Combofix.txt) in your next reply.
Please post an uninstall list using hijackthis. Open hijackthis, click on open misc tools section, click on open uninstall manager, click on save list and save it. Then copy and paste that log back here along with the combofix log and a fresh hijackthis log.
Hi John
I did as requested, below are the reports.
ComboFix 11-04-28.03 - Daniel 29/04/2011 13:45:23.2.2 - x86
Command switches used :: c:\users\Daniel\Desktop\CFScript.txt
* Resident AV is active
((((((((((((((((((((((((( Files Created from 2011-03-28 to 2011-04-29 )))))))))))))))))))))))))))))))
2011-04-29 12:32 . 2011-04-29 12:32 -------- d-----w- c:\users\Daniel\AppData\Local\{E810439A-4933-4878-B3F7-103FFF830CE0}
2011-04-28 19:27 . 2011-04-28 19:27 -------- d-----w- c:\users\Daniel\AppData\Roaming\Malwarebytes
2011-04-28 19:27 . 2011-04-28 19:27 -------- d-----w- c:\programdata\Malwarebytes
2011-04-28 15:56 . 2011-04-28 15:56 784136 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight\SpotlightResources.dll
2011-04-28 15:55 . 2011-03-03 15:40 28672 ----a-w- c:\windows\system32\Apphlpdm.dll
2011-04-28 15:55 . 2011-03-03 13:35 4240384 ----a-w- c:\windows\system32\GameUXLegacyGDFs.dll
2011-04-28 15:54 . 2011-03-12 21:55 876032 ----a-w- c:\windows\system32\XpsPrint.dll
2011-04-17 22:21 . 2011-04-17 22:21 -------- d-----w- c:\programdata\TorrentEasy
2011-04-16 11:39 . 2011-04-16 11:39 -------- d-----w- c:\users\Daniel\AppData\Local\Trusteer
2011-04-03 15:20 . 2011-04-03 15:25 -------- d-----w- c:\users\Daniel\AppData\Roaming\Garden Planner
2011-04-03 15:20 . 2011-04-03 15:20 -------- d-----w- c:\programdata\Garden Planner
2011-03-03 15:40 . 2011-04-28 15:55 173056 ----a-w- c:\windows\apppatch\AcXtrnal.dll
2011-03-03 15:40 . 2011-04-28 15:55 542720 ----a-w- c:\windows\apppatch\AcLayers.dll
2011-03-03 15:40 . 2011-04-28 15:55 458752 ----a-w- c:\windows\apppatch\AcSpecfc.dll
2011-03-03 15:40 . 2011-04-28 15:55 2159616 ----a-w- c:\windows\apppatch\AcGenral.dll
REGEDIT4
2010-10-06 23:36 94208 ----a-w- c:\users\Daniel\AppData\Roaming\Dropbox\bin\DropboxExt.14.dll
"aux"=wdmaud.drv
2011-04-29 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
2011-04-29 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2011-04-29 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-590934792-190235506-1732831347-1000Core.job
2011-04-29 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-590934792-190235506-1732831347-1000UA.job
Rootkit scan 2011-04-29 13:59
hidden files: 0
--------------------- DLLs Loaded Under Running Processes ---------------------
- - - - - - - > 'Explorer.exe'(4080)
c:\progra~1\mcafee\SITEAD~1\saHook.dll
Completion time: 2011-04-29 14:02:38
ComboFix-quarantined-files.txt 2011-04-29 13:02
ComboFix2.txt 2011-04-28 22:54
Pre-Run: 19,029,934,080 bytes free
Post-Run: 19,006,402,560 bytes free
- - End Of File - - B30892C6AF06C5C7340055E3CA13192C
Uninstall List...
Update for Microsoft Office 2007 (KB2508958)
7-Zip 9.15 beta
Activation Assistant for the 2007 Microsoft Office suites
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Photoshop 7.0
Adobe Reader 8.1.4
Adobe Shockwave Player 11.5
Apple Application Support
Apple Mobile Device Support
Apple Software Update
Ask Toolbar
Atheros Driver Installation Program
Atheros Wi-Fi Protected Setup Library
BitLord 1.1
Bonjour
CD/DVD Drive Acoustic Silencer
Cisco EAP-FAST Module
Cisco LEAP Module
Cisco PEAP Module
Command & Conquer 3
Compatibility Pack for the 2007 Office system
CutePDF Writer 2.8
D3DX10
DivX Codec
DivX Converter
DivX Player
DivX Web Player
DoremiSoft AVI to MP4 Converter 1.0
DVD MovieFactory for TOSHIBA
Free Convert to DIVX AVI WMV MP4 MPEG Converter 5.8
Free Mp3 Wma Converter V 1.91
FreeArc 0.666
FreezeSMS
Full Tilt Poker
Garden Planner 2.5
Google Desktop
Google Earth Plug-in
Google Toolbar for Internet Explorer
Google Update Helper
GPL Ghostscript 8.63
HiJackThis
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
Intel(R) Graphics Media Accelerator Driver
Intel® Matrix Storage Manager
iTunes
Java(TM) 6 Update 24
Java(TM) 6 Update 6
Java(TM) 6 Update 7
K-Lite Codec Pack 4.0.0 (Full)
LG USB Modem driver
McAfee Internet Security
Microsoft .NET Framework 1.1
Microsoft .NET Framework 1.1 Security Update (KB2416447)
Microsoft .NET Framework 4 Client Profile
Microsoft Internet Explorer 5 Toolbar Wallpaper
Microsoft Office 2007 Service Pack 2 (SP2)
Microsoft Office Click-to-Run 2010
Microsoft Office Excel MUI (English) 2007
Microsoft Office Home and Business 2010 - English
Microsoft Office Home and Student 2007
Microsoft Office Live Add-in 1.5
Microsoft Office OneNote MUI (English) 2007
Microsoft Office PowerPoint MUI (English) 2007
Microsoft Office PowerPoint Viewer 2007 (English)
Microsoft Office Proof (English) 2007
Microsoft Office Proof (French) 2007
Microsoft Office Proof (Spanish) 2007
Microsoft Office Proofing (English) 2007
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
Microsoft Office Shared MUI (English) 2007
Microsoft Office Shared Setup Metadata MUI (English) 2007
Microsoft Office Word MUI (English) 2007
Microsoft Silverlight
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
Microsoft Visual C++ 2005 Redistributable
Microsoft Visual C++ 2005 Redistributable - KB2467175
Microsoft Visual C++ 2008 Redistributable - KB2467174 - x86 9.0.30729.5570
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
Microsoft Works
Mozilla Firefox (3.6.16)
MSVCRT
MSXML 4.0 SP2 (KB941833)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
myphotobook 3.6
OGA Notifier 2.0.0048.0
OpenOffice.org Installer 1.0
PartyPoker
Project64 1.6
QuickTime
Rapport
Rapport
Realtek 8169 8168 8101E 8102E Ethernet Driver
Realtek High Definition Audio Driver
Realtek USB 2.0 Card Reader
Remote Mouse Server version 1.05
SAMSUNG Mobile Modem Driver Set
Samsung Mobile phone USB driver Software
SAMSUNG Mobile USB Modem 1.0 Software
SAMSUNG Mobile USB Modem Software
Samsung PC Studio 3
Samsung PC Studio 3 USB Driver Installer
Security Update for 2007 Microsoft Office System (KB2288621)
Security Update for 2007 Microsoft Office System (KB2288931)
Security Update for 2007 Microsoft Office System (KB2345043)
Security Update for 2007 Microsoft Office System (KB2466156)
Security Update for 2007 Microsoft Office System (KB2509488)
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for 2007 Microsoft Office System (KB976321)
Security Update for Microsoft .NET Framework 3.5 SP1 (KB2416473)
Security Update for Microsoft .NET Framework 4 Client Profile (KB2446708)
Security Update for Microsoft Office Excel 2007 (KB2464583)
Security Update for Microsoft Office InfoPath 2007 (KB979441)
Security Update for Microsoft Office PowerPoint 2007 (KB2464594)
Security Update for Microsoft Office PowerPoint Viewer 2007 (KB2464623)
Security Update for Microsoft Office system 2007 (972581)
Security Update for Microsoft Office system 2007 (KB974234)
Security Update for Microsoft Office Visio Viewer 2007 (KB973709)
Security Update for Microsoft Office Word 2007 (KB2344993)
Security Update for Windows Media Encoder (KB2447961)
Security Update for Windows Media Encoder (KB954156)
Security Update for Windows Media Encoder (KB979332)
Segoe UI
Serif PagePlus SE 1.0
Sky Broadband
Sky Broadband Browser Branding
SmartDraw PDF Filter
Synaptics Pointing Device Driver
The KMPlayer (remove only)
TorrentMan Toolbar
TOSHIBA Assist
TOSHIBA ConfigFree
TOSHIBA Disc Creator
TOSHIBA DVD PLAYER
TOSHIBA Extended Tiles for Windows Mobility Center
TOSHIBA Hardware Setup
TOSHIBA Manuals
TOSHIBA Recovery Disc Creator
TOSHIBA Software Modem
TOSHIBA Supervisor Password
Toshiba TEMPRO
TOSHIBA Value Added Package
TRDCReminder
TRORDCLauncher
Update for 2007 Microsoft Office System (KB967642)
Update for Microsoft .NET Framework 3.5 SP1 (KB963707)
Update for Microsoft Office 2007 Help for Common Features (KB963673)
Update for Microsoft Office Excel 2007 Help (KB963678)
Update for Microsoft Office OneNote 2007 (KB980729)
Update for Microsoft Office OneNote 2007 Help (KB963670)
Update for Microsoft Office Powerpoint 2007 Help (KB963669)
Update for Microsoft Office Script Editor Help (KB963671)
Update for Microsoft Office Word 2007 Help (KB963665)
VLC media player 1.1.7
Windows Live Communications Platform
Windows Live Essentials
Windows Live ID Sign-in Assistant
Windows Live Installer
Windows Live Messenger
Windows Live Photo Common
Windows Live PIMT Platform
Windows Live SOXE
Windows Live SOXE Definitions
Windows Live UX Platform
Windows Live UX Platform Language Pack
Windows Media Encoder 9 Series
Windows Media Player Firefox Plugin
WinRAR archiver
WinZip 14.5
Zynga Toolbar
New hijackthis report...
Scan saved at 23:59:22, on 28/04/2011
Boot mode: Normal
Running processes:
C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
C:\Program Files\TOSHIBA\ConfigFree\CFSwMgr.exe
End of file - 13644 bytes
Also John, I dont remember having a Local Disk (Q) but its there, it doesnt say total size or free space and when i click on it it says not accessible, access is denied?
Please uninstall the following programs via add/remove programs in control panel
Adobe Reader 8.1.4
Ask Toolbar
Java(TM) 6 Update 6
Java(TM) 6 Update 7
TorrentMan Toolbar
Zynga Toolbar
Then go here to download the latest adobe reader software.
http://get.adobe.com/reader/?promoid=BUIGO
All those hijackthis entries I asked you to fix are still there, did you run the fix? If not please redo the hijackthis scan and place check marks next to those entries if they are there.
Reboot the pc and post a fresh hijackthis log.
Can you give me a screenshot of your disk management screen please?
I uninstalled all programs except the ask toolbar. It gave me the error message:
Error 2738.Could not access VBScript run time for custom action.
I did run the fix first time round so not sure why that happened. Anyway I did it again and below is a new report and link to screen print
http://www.picvalley.net/v.php?p=u/1814/13565945217665627771304119952NqYSq6Y4mYwAfcSHrlDU.JPG
Scan saved at 00:14:01, on 30/04/2011
Running processes:
c:\PROGRA~1\mcafee.com\agent\mcagent.exe
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\RunOnce: [Uninstall Adobe Download Manager] "C:\Program Files\NOS\bin\getPlusUninst_Adobe.exe" /Get1noarp
O4 - Global Startup: McAfee Security Scan Plus.lnk = ?
O23 - Service: McAfee Security Scan Component Host Service (McComponentHostService) - McAfee, Inc. - C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe
End of file - 10293 bytes
According to that link you posted there is no local disk Q, only a hidden partition labeled eisa configuration which needs to be left alone as that is part of your recovery program.
Unfortunately, infections can cause issues that won't go back to normal after removing it. So either you will have to try fixing those issues manually or just deal with it until you can reinstall windows. If you can list your current issues, maybe I can offer some suggestions on what to do to try and fix them.
Thank you for ur help. Things seem to be back to normal now. My only questions if there is any way to tell if the viruses managed to do their job? Did they steal any data, cause any harm? I can't understand why my av didn't pick 13 up, and it took a free download to fix when I had a full av version?
There isn't one program out there that will catch everything. If you really want to protect yourself better then I would suggest buying the paid version of Malwarebytes. It's an active malware scanner when ever your computer is on. It updates usually more than once a day, the company is very good about keeping up with the latest malware that comes out on a daily basis. Are you using a web site search advisor like Web of Trust or something similar? These type of broswer addons tell you if a website it safe to visit or not when doing searches.
Also remember that there are only about 5 percent of todays infections are actually viruses, the other 95 percent are actually rogue malware programs. Everyday there are around 5 to 10 new rogue programs come out.
You are safe as long as you didn't enter any credit card information when those rogue programs started appearing telling you that you needed to buy their software to rid your pc of infections.
I run the free version of Avast with the free version of Malwarebytes. Avast comes with a site advisor addon called Webrep.
help?
So as described in the very first post, I had the same exact problem with my laptop. I was able to download and run malwarebytes anti-malware in safe mode. however upon restarting my lap top there is alot missing that I dont know how to replace. For instance, i already knew everything was gone, the only icons there are the malwarebytes and the hijackthis and the installer for malwarebytes. but how do i recover the basics like the internet explorer icon, the recyle bin so on and so forth?
Also...
Sorry for a double post, but as an afterthought would it make sense to restore from a restore point?
I am sorry to bother ya'll and I thank you in advance, I just don't know what to do...
