Purchasing Parts soon.. Please review build
I wouldn't recommend biostar motherboard. You will find better products from asus, gigabyte, msi.
Great case, I have it as well. I like the dedicated ssd drive slot on the bottom of the case.
My budget is around $600. I'd like to play newer games and BF3 when it comes out. They dont have to be maxed out; just normal-high. Do you think this build would do the job?
Thank you!
Andy
change the hdd to a wdd black 640gb
http://www.newegg.com/Product/Produ...n_digital_caviar_black-_-22-136-544-_-Product
and memory you had 1333mhz and your mobo supports 1600mhz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
ripjaws 1600mhz
otherwise everything looks great, now I have never played crysis before however I have played mw2 with a 4870 w/512mb and it ran flawlessly with a quadcore so I would imagine you should be fine your build looks great also make sure to post some pictures and best of luck :].
Also for consideration possibly might want to go with a antec 300 illusion case, the 912 is just fine and I have done custom builds with it before but I do like antec cases a lot.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
