FXB
I got the MB installed, I put in the chip and thermal compounded it then put the cooler fan on and actually figured out where to plug it into. I then installed the GSkill memory no problem. I installed the power source but have no idea where to plug that into, there's like 4 different plugs on it. I also put in the CD/DVD rom but don't know where to plug that into either.
Think I'll get something to eat before I try to figure anything else out... any help, fellas?
If you read the manuel that came with your mobo there should be a layout diagram that labels everything you can also find some info in the PSU manuel.
To connect your PSU to the mobo there is a 24 pin connector that is the one that powers your motherboard.
What type of power supply do you have? Which motherboard do you have?
