So I've come across a bit of a problem here...
After having network problems with Vista (can't get a wireless signal), I decided to install XP SP2 to a seperate HDD. Everything is going pretty well overall until I realized that when I boot XP, there is no boot menu- there's no way I can get back to Vista. I have looked at the M$FT website, among others, and found that everyone recommends installing XP from Vista and using Vista's new-and-improved boot.ini (which isn't really a boot.ini at all) to manually add-in XP. Well I did it the other way around and XP's boot.ini won't recognize Vista since it doesn't even have such an entry. I've looked all over and can't seem to find any way that I can either a.) boot to Vista so I can set all this up from that end or b.) manually add-in Vista to the boot menu from the XP partition.
Any help would be greatly appreciated!
Frustrated and
Ben
Frustrated and
Ben
