Geoff
Raising the voltage over the stock voltage will.another thing, does overclocking shorten the life of the cpu?![]()
That's debatable, but it is said that it does.another thing, does overclocking shorten the life of the cpu?![]()
ok so ive finalled a list but need help to see if its all compatible
- ASUS P5Q - Motherboard - ATX - iP45 - LGA775 Socket - UDMA133, Serial ATA-300 (RAID) - Gigabit Ethernet - FireWire - High Definition Audio (8-channel)
- EZCOOL Super Silent 700Watt
- Arctic Silver 5 3.5g Thermal Paste
- Akasa AK-170CB-4BLS 8cm Blue LED case fan
- Arctic Cooling Freezer 7 Pro Socket 775 CPU Cooler
- Intel Core 2 Quad Pro Q6700 "LGA775 Kentsfield" 2.66GHz (1066FSB) - OEM
- OCZ Gold Edition 4GB (2x2GB) DDR2 PC2-8500C5 Dual Channel (OCZ2G10664GK)
- Asus ATI Radeon 3450 Vcool Silent 512MB DDR2 TV-Out/DVI (PCI-Express) Retail (EAH3450/HTP/512M)
all for £410 (hes already got a monitor, keyboard, mouse, case)
he wont be gaming so i dnw whether he'll need a beta graphics card?
amazon and overclockers
Well, it kind of futureproofs a computer to have a better graphics card, plus sooner or later we will start to see programs using video cards for work(video cards are highly paralell compared to cpu's). So id recommend even just a 4350 over 3450:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-042-GI&groupid=701&catid=56&subcat=1274
And since the Q6700 is on sale its prolly the best cpu for the price, but this cpu cooler would allow you to overclock further and keep low temps:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-TQ&groupid=701&catid=57&subcat=1395
Also, do you have a link to the power supply in your list?
a couple of things, the CPU cooler will most likely come pre applied with a thermal pad.
Also what type of computer is the one that the case is from. If it's a prebuilt machine (like a Dell) then there is a very strong chance that the new stuff won't fit in the old case. Just to warn you.
The motherboard may come with a SATA lead. If you look on the manufacturers website it should give you a more detailed list of what comes in the box.
