Post A Pic Of Your Pc Here :)
damn you! I hoped I could be rude about your first build, but this actually looks pretty nice.
Hope you don't get the same problem as I had with those Dominator fans tough.. after a fairly short time, they started making a lot of noise when I started up my pc (as if the grease in the bearings leaked to 1 side, so they were running dry on startup.) after a minute they'd run normal. so its not THAT bad, but it was annoying, so I took that thingy out of my pc.
It's my second build, sold the first one to my sister :) (you could probably have been rude about that one, as well!) Thanks for the tip about the dominator fan, I'll keep an eye on it.
Looks great Buzzy.....Whats the specs? :)
Err, E8500, gtx260, 4Gb ram, WD 1tb hdd, Seasoninic 700W, Gigabyte EP45- UD3P
Pentium 486
512kB RAM (with shared video ram)
4Mb hdd
:P
That was my first build! :P
Haven't tried any games yet, but it seems to be folding like hell!
Yes it does:D
I have done some testing with folding at stock speeds and overclocked. I might get a few seconds difference per percentage point in the work log. Really almost no difference. I have been working alot teaching classes...haven't folded much the last few weeks:(
enjoy the new card:)
what my new pc is.
Phenom II X4 920//GeForce GTX 260//1TB Seagate HD//4GB RAM//Vista x64 Ultimate-Ubuntu Hardy Heron (I stick with LTSes) 64 bit dual boot.
I will show my compiz sexiness when I get get done with it. I just reinstalled both OSes and it was a pain since I got a new HD!
Bit of an update, to show my "metal shop mod"
i finally got sick of bending my side, so i cut out a 6.5"X5" square, MIG welded four 4" angle irons to the corners, then welded the square to the end of the angle irons.
after that, i drilled some holes and bolted some Lexan to the inside of the box. turned out pretty nicely if i dont say so myself :rolleyes:
Thats neat :good:
Been a while. heres another of mine without crossfire again.
And for the heck of it.. :P
I've got to do something about my rug, my entertainment crap is half on it and half on hard wood. As well is my couch. I need to paint my room too :(
But, i got my sound and video hooked up to my receiver and TV too. HDMI and coaxial. :D
What kind of speakers are those
