bomberboysk
Nice setup and wire organization. When I'm done building I think its going to look like a jumbled mass of cords.
Naw, zip ties are a pc builders best friend
Naw, zip ties are a pc builders best friend![]()
Those are the things that you can put in but you can't take out right?
And how can i PM/IM you?
PM- you would need 100 posts. For my msn im check my profile page under contact info, dont wanna post it here because of spambots that are sometimes on the site. Yeah, zip ties are the things you need to cut to get off, but are the best things for cable mangement due to how they hold with a good grip(unlike others such as velcro straps).
K I was wondering if you could help me with msn IM to build the computer?(next weekend)
And I've seen other people use electrical tape but zip ties sound easier/better.
yeah, electrical tape can also leave residue on your case/wires. And sure, would be glad to help you out. Best place ive found for zip ties is walmart(just checked prices today, they had then for $2.79 for 75 5" long ones here) and harbor freight usually has a good selection of zipties.
We don't have any walmarts around here, but I'm sure they're at Fred Meyer
Edit: I'm online got you added.
Change it to @hotmail.com for the last part vs @live.com, not using my @live.com account at the moment, whoops.
You going to get on?
I am on at the moment...lemme check if i got any add's. You could post me a visitor message (on my profile here)with your msn im id and ill add you though too.
Edit: Nerp, just shout me your msn id onto my visitor messages and ill add you.
Uhh i don't think i have enough posts for that![]()
http://www.computerforum.com/members/36523-bomberboysk.html
Just post it there in the little message boxNo post requirement for that, PM is unlocked at 100 posts though.
Edit: Meh..Ill just deal with spam if it hits me, but you did add bomberboysk(At symbol here)hotmail.com correct?
