Lol xD vb scripts I just looped some program to open lol
I'm going to use CD tray script at school tomorrow if no snow day >
The "nicer" things I've done would be fake BSOD screens, pop-up windows, and changing system sounds.
Probably the nastiest thing I've done is this:
A resource hogger.
What we'll (I've taught this to a few people), is write a program that will
do the following:
1. Copy itself to the hard drive. (specifically the startup folder)
2. Rename itself to some anti-virus program... (or anything that's trusted)
2. Launch the advanced computer settings window.
3. Pause
4. Allocate every single last byte of free space on the boot drive into a hidden file.
5. Then allocate memory equal to double the physical memory.
EDIT 2: I forgot a step:
6. Spawn as many threads as there are logical cores.
7. Have each thread go into an infinite loop that will random access the memory.
Now here's how we can trigger it in under 20 seconds:
1. Configure autoplay on a flash drive to launch the executable.
2. Insert the flash drive. It will autorun, copy itself, and launch advanced settings.
3. Manually set the pagefile to something very large. (I can't do this programmicly because of security measures in Windows.)
4. Restart the computer.
And that computer is basically done for...
EDIT: Without a separate boot drive, it would take hours to disable it because the system is non-responsive.
EDIT: This was payback for something REALLY nasty someone did to me...
