Motorcharge
Well-Known Member
Back in September I started having some odd problems out of the blue one afternoon. PC worked fine the night before, then the next morning I powered on, things ran fine til I'd run a game. As soon as I did the PC would lock up. Restarted a few times, same thing, only froze when I ran a game. After the 3rd or 4th reset I went to power back on and my system would come on, but I'd get no video and I'd get a "no input" message on my monitor.
Figured it might be the PSU, swapped in a new one, no luck. Upon further inspection I found a bulged capacitor on the mobo (abit ip95).
Got my new motherboard in about an hour ago, hooked everything up and same problem. I've tried swapping out 2 different PSUs and 2 different vid cards and nothing has worked. As far as I can tell, theres nothing physically wrong with the CPU.
Ideas?
I'll post some pics of how everything is hooked up in a couple minutes. It's been a while since I've put a comp together, possible I did something wrong.
edit: only difference from my sig is I'm on XP (7 isnt installed yet) and on 4 gigs of RAM, not 8 for now.
Ideas?
