Post A Pic Of Your Pc Here :)
i covered up the white around the usb ports and under teh dvd. it's some kind of foam padding used for shipping stuff. also works as a air filter.
not bad :)
The USB ports look great, but the padding under the cd rom looks like it needs pushed in more or something.
Good Lord! What are the specs on that?
it's a via epia px10000g
Processor: VIA C7 1.0GHz NanoBGA2
Chipset: VIA VX700 Unified Digital Media IGP Chipset
Memory: 1 DDR2 533 SODIMM socket
Up to 1GB memory size
VGA: Integrated VIA UniChrome ProII 3D/2D AGP graphics with MPEG-2/4 and WMV9 decoding acceleration
LAN: 1 VIA VT6106S 10/100Mbps Ethernet controller with Power Management Functions
IDE: 1 UltraDMA 133/100/66 connector (2.0mm 44-pin header)
Serial ATA: 1 SATA connector
Audio: VIA VT1708A High Definition Audio Codec
I/O Connectors:
4 USB pin headers for 4 USB 2.0 ports
1 COM port connector
1 PS2 mouse/keyboard pin header
1 LVDS/DVI connector
1 Multimedia connector to support external TV-out interface, Video capture port interface and Low pin count interface (an add-on card is required)
1 Audio pin header for line-out, line-in, mic-in, S/PDIF in, and 7.1 channels audio output
1 Fan pin header for CPU fan
1 Pico-iTX power connector5
not bad for it's size ;!!! :)
I have a gameboy you could have :P
is it the original kind?
man, that mobo costs over $200. i really can't think of any use for a computer that small. how much do you think it will fetch all modded up on ebay?
maybe if it had two nics, you could set it up as a firewall. idk.
did another mod on my antec 902. the hard drives now are sideways. looks way better without the cables sticking out in front of the psu and the hard drives no longer stick out. now i just need a cpu power cable extension so i can run it behind the mobo instead of in front of it.
I just built a new backup PC, total invested is $375...but I'm gonna get a 74gb raptor or 2 for it to boost the speed a little.
Here's specs-
Cooler master centurion case
Asus P5Q-E P45 motherboard
E6750 (currently at 3.2ghz stock Vcore, 400x8)
2x1gb ddr2-800 ram
Zerotherm Zen cooler
8800gt 512mb
maxtor 250gb HDD
650w PSU
DVD rom
Card reader
I'm not a huge fan of top mounted PSU's because it's hard to get a clean look, but not bad IMO-
Few Upgrades :P
Core i7 920 @ 4.0Ghz (Megahalems Mega SHadow)
Gigabyte GA-EX58-UD4P
Enermax Infinity 720W
6GB OCZ Platinum
SAPPHIRE HD 5870 VAPOR X
here's my server, Blackmesa :)
Pentium 3 @ 1000 Mhz!!!
1.5GB pc133 ram
geforce3 card for console
two nic cards (i have two networks).
a usb 2.0 card for external drives, etc.
running ubuntu server 9.10 without monitor or kb/mouse
the case itself is nothing flashy, but it's a sturdy machine.
just finished formatting my 1TB sata drive, so i'm gonna finish configuring it :)
6GB OCZ Platinum
Thanks for updated the specs, but If I could make a suggestion....I have the same PSU, and I know it's REALLY close but you can run the CPU power plug underneath the board and come out up top right by the plug. Your cpu power plug on the board is in the same location as mine so I know it will work!
Here's mine-
what are your temps on that noctua cooler luke?
i got one on my i7 920@stock and its idle at 45c, i sold my liquid cooling and im gutted at the heatsink-absolute garbage!
gonna buy a new water loop cos i cant oc on them temps
