Post A Pic Of Your Pc Here :)
^^ I know I totally want to buy one but, my car's alternator must come first. If I have money left I am going to pick one up and a new power supply.
Edit: The only thing it is lacking is a Window and a CF decal! lol
But for a mere $10 at frozencpu you can get a window kit or a trip down to the hardware store
Got my 5830 in and 3rd monitor setup....5760x1080 resolution.....WOOT!
monitors look funky colors because of the camera angle-
looking good :good: how well does the 5830 work in eyefinity mode?
50-90 FPS playing COD WAW solo, and 90-125 FPS playing multiplayer. So I'm pretty impressed, no noticeable lag at 5760x1080 res is amazing. This was overclocked to 925 core and 1125 memory. I've got 950/1200 stable now so I'm gonna try again.
wow, that is quite amazing. usually the lowest cards of a series are worse than the ones of the series just below it... looks like ati did a good thing releasing that card :rolleyes:
Only two more weeks here at school then she moves back under my bed at home :)
Gotta get another monitor, keyboard, mouse, and audio cables cause she's gonna be my secondary. The two monitors pictured are going on my new rig [specs in sig].
i'm honored to be the one with the post on your screen :P
hopefully i'll finally get a quad-core under that zalman :rolleyes:
it's too bad the majority of the older games don't scale very well with eyefinity.
I just downloaded this thing called widescreen fixer, and it works GREAT! Now it's like it should be, not just what you'd normally see on one 1920x1080 monitor stretched out into 3 monitors. I'll post a pic in a few minutes.
fairly sure CoD WaW, just before the driver on the front left gets a bullet through the face
Yes sir!
Fixed eyefinity-
Old one-
That setup would be sweet with some of those $300 NEC IPS panels for the surround, much better viewing angles than TN panels(better color reproduction as well). (Not that that setup isnt hella amazing as is, cause its pretty sweet)
The color is way better than the pic portraits, but yeah I see what you're saying.
amazing setup dude are all the monitors identical?
Thanks!
They are all 21.5'' 1920x1080 Acer's, the two outsides are E211H's and the middle is an H213H.
