Submitted mine,Nice one bomber:good:
Il probably be somewhere down the bottom once everyone else starts submitting with their i5s and i7s![]()
No problem, i'll accept that score, just in the screenshot box place a space between your two url's with a current cpu-z screenshot(for continuity sake).![]()
How'd you get a 550? They aren't our yet, are they? It's just an i5 650 without turbo, right? Guessing it's better for OCing than the 650?Well since it must be currently owned hardware, guess my 7.677 with an I3 is out. However, I have an I3 550 extra spicy in my possesion right now thats just itching to get benched
Can I just use time.gov for the timestamp? Because my SS's I cut down and it takes the windows time out of the screen. Also, why do you require a date on the notepad if it has to be timestamped anyway?
Time.gov works fine, although right clicking on adjust date/time and opening that window works as well.Well since it must be currently owned hardware, guess my 7.677 with an I3 is out. However, I have an I3 550 extra spicy in my possesion right now thats just itching to get benched
You're seeing thingsThe AMD+Intel rankings list says "Top 50" but there are only 25 spots. I don't know if that's the way you meant it to be.
Awesome job though!
Also, nice OC on the i7 860.Your new nickname is officially super-overclock-variety-man
You're seeing things![]()
I see what you did there... lol
I have connections, it's an extra spicy chip. This chips hits 5ghz on air with HT on![]()
holy hell, what temps is that though?
Nothing out of range, may peak into the 90's if 100% loaded using real temp and 1.50 Vcore............I'm using a zerotherm zen. I'm hoping to get to ~5.2ghz with HT off for the SPI contest. Maybe 6ghz on DICE, who knows.
Forgot to change my sig too, I'm running an EVGA P55-FTW now.
Real temp uses the core temp, not the actual CPU's temp. The CPU temp max spec is around 72c, but core temp max is around 105c. The Core 2 chips also have around 100c max core temps.
With prime95 loaded and the CPU is in the 90's, when you exit prime the CPU temp immediately drops in the 60's because the cores are no longer stressed so they go back to the actual CPU's temp.
Wow. Guessing that's #1?Nothing out of range, may peak into the 90's if 100% loaded using real temp and 1.50 Vcore............I'm using a zerotherm zen. I'm hoping to get to ~5.2ghz with HT off for the SPI contest. Maybe 6ghz on DICE, who knows.
wait for it linkin...bam http://spreadsheets0.google.com/viewform?hl=en&formkey=dGNhMVQ2RUtMdkNTYzNpU29EN1JNeUE6MQ
you were meant to use that
=EDIT=
bbsk, can we put the screenies here for others to see too, or will you be posting them up, or is it just a no?
