hey i want to kinda upgrade my CPU but im still kinda nooby with computer, im wondering which CPU i should get for my upgrade:
1) CPU/Processors - AMD Athlon 64 X2 5200+ Dual Core Socket AM2 2.6GHz - ALTHONX2AM2/5200
site: http://www.liata.com/scrItem.asp?product_subtypes_id=693&product_types_id=19&product_id=7342
or
2) AMD Athlon 64 X2 5200+ Processor ADO5200IAA5DO - 2.70GHz, Socket AM2, 1MB Cache, 1000MHz (2000 MT/s) FSB, Brisbane, Dual-Core, OEM
site: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4690900&CatId=2328
*note* this one is OEM package, with no fan or heat sink gotta buy it separately
which one should i get out of those two? i realize that the second choice are compatible with some new motherboard and the first choice doesn't (l2 cache, also i might buy a new motherboard if that is the problem to my pc)
PC Spec ATM:
motherboard: asus m3a
CPU: amd athlon 64 x2 4000+
ram: patriot ddr2 1gb (2 sticks)
hdd: western digital 16mb buffer 250gb
gfx: dual screen nvidia geforce 8400 gs
power: 500W deer
or
PC Spec ATM:
power: 500W deer
