I recently built my first computer with the following specs.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103075
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136168
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103699
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161338
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130275
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146059
It seems to be running just fine. It powers on, the LED's work on the case just fine. Everything is in place, I believe, but I don't get anything from when I plug my monitor into the video card. So the computer seems to run, but I can't see anything?
Here's the deal with what I have plugged in.
I have the motherboard screwed in with the spacers between it and the case, and the 24bit cord plugged into it, from the power supply.
I have the CPU dropped into the socket, locked down. I put the heating adhesive on it and then the fan locked ontop of it. The fan is plugged into the "CPUFAN" slot
I have an 8pin cord plugged into the power supply, and then the other side plugged into the extender, and then plugged into the CPU power connector.
I have one 2gb stick plugged into one black slot, and the other 2gb stick is not in the computer yet.
I have a 6 pin cord that goes from the power supply up to a cord that fits in my disk drive, and then it works its way back to the hard drive.
In both the disk drive and the hard drive, I have 2 sata cords plugged into the motherboard.
I have a 6 pin from the power supply plugged into my case fan, which is plugged into SYSFAN1.
I have my video cards plugged in. It is the Radeon HD 5770 plugged into the PCI Express slot. The fan works. It has a 6 pin slot on it, which I have plugged into the PCI-Express 8pin to 6pin that I got with my power supply.
I plug the power supply into the wall, turn it on. All the fans run. My CPU Cooler Master, the case fan and my video card fan. LED's work, but no video, and no beep when I start my computer.
I am beginning to think something might be short circuited or DOA. Or am straight up missing something.. or it has to be something really small that I don't have right. Any ideas?
