The GTX 260 is registered with eVGA to me...whoever buys this card I will always help with any RMA for any CF member.
Bump
Cheers mate
That is if it sells, it depends almost entirely on the (possible) sale of a GTX460. If there isn't one available, or someone offreing a better card, I will happily stick with these 2.
No, My case isn't even corsair. It just initially looked the same.
This is mine.
Aaah I see, it has some pretty awesome features for the price.
I don't particularly like it looks wise though, but it is the same with pretty much every case - I only like plain cases. No random edges and grills, no lights, no go faster stripes, none of that, with mine it is plain, it has just the Corsair logo on, the front is sexy as hell because it is flat, brushed black aluminium, there are no lights, it is a grown up case. It is designed to be a practical case. Compare it to a car, it doesn't have a side panel, like a yobbo who done did up his to make it go well fast, so spends his time with the bonnet open showing off the "shiny". It doesn't have an uneccesary spoiler or bits of plastic hanging off it "because it looks cool". It doesn't have lights or a fart can on the back, it is a proper case, it isn't over engineered, it is all done to perfection, and every little thing has been thought of and aesthetically, it is perfect.
However, it is also a fair bit larger than yours (not that yours is small by any means
), which I am not complaining about when working on it, but when it is under your desk and one of the corners is at thigh height on a revolving chair... I think you can see the problem there
And it is a hell of a lot heavier (44lb compared to your 30lb), nearly give myself a heria every time I try to shift it, but I supose that can be expected with a lump of steel/aluminium that size
It cost me an arm and a leg, but I do not regret buying it for a single second, it is such a work of art and a worth while investment that will last a hell of a long time, and never go out of fashion (at least to me)
