What happened to your 460?
I doubt thats the reason.....try swapping the sticks over to the other two slots. Perhaps the ram itself just can't handle the higher speed. Lower end sticks are like that sometimes.
Also, the IMC's on the Athlon II's aren't very good. It's hard to find a deneb Phenom II that'll run 1600 ram with tight timings. Only the Thubans and a very select few deneb's can do it. But all the athlon II's have weak IMC's.
C2 and C3 doesn't matter that much, only the E0 stepping thubans can handle the higher speeds and/or tighter timings.
Usually the phenom II C3's can handle 1600 with loose timings, so the combination of yours being a C2 and also an Athlon is just a double whammy and inevitably a weak IMC. I had a 955 that could do 1600 7-8-7 but no further or tighter timings, when my 1055t could do 5-6-5 on the same sticks.
So like I said, it's either the IMC or the sticks themselves, not the board causing any issues. Corsair is one of the most accepted brands, plus memory support lists are bogus anyway. The list is usually very short and I almost never have had ''officially'' supported ram in any boards.
You're saying they ran 1600 fine on a different board?
Thats really weird then for XMS3's.
Thats a pretty nice case mod you did there.Really good.
But that bulge for the HDD slots makes your PC look pregnant
JK LOL
And is that an Acer monitor??
Holy wires everywhere batman!![]()
And yup, Acer, as it says in my sig.
Yeah, got a lot of fans in there...
No Sig
He mean your cable management needs improvement.
Yeah, I just changed it, haha.
And my CPU stays at a constant 36c and my GPU at about 40c on idle. Cables don't get in the way that much.
