If so, you probably didn't grab the right code. You grab everything between the "=" and "&" in the video code.
Ex in bold: http://www.youtube.com/watch?v=1-TYQXjk7lc&feature=youtu.be
I don't know whether this is an issue or not,
but when not logged in on CF the birthday lists remains the same as the last time I was logged in.
They only change on a daily basis. Do you have your time zone set correctly in user CP?
I am not able to reach CF.Using proxy servers to reach CF.Error 403
We're sorry, but we could not fulfill your request for / on this server.
You do not have permission to access this server. Before trying again, run anti-virus and anti-spyware software and remove any viruses and spyware from your computer.
Your technical support key is: 73f0-1ddb-2b02-1b1f
You can use this key to fix this problem yourself.
If you are unable to fix the problem yourself, please contact ian(@)computerforum(.)com and be sure to provide the technical support key shown above.
tried both windows and ubuntu.
If you can, continue to use a proxy to log into the site. Without going into too many details, we're working on a few things behind the scenes, and, for the time being, a small number of you may encounter this error. Using a proxy is probably the best method to avoid this error.
Ok Sir. :good:
Any Estimated time of completion ??
And is no - one else besides me getting this problem??
I am also able access it through my phone and the problem arises at the same time every night.
Anyways will use proxy till then.
Things aren't loading fully. Well they are, but every single CF page is still "loading" waiting for c.statcounter.com
Ever since today, any time I quote someone, it says underneath "You have selected 1 post that is not part of this thread. Quote this post as well, or deselect this post."
Test.
Working fine for me at the moment.
I also seen it. Runs fine other than that. running fast for me also. just the error message above.
