November Folding Marathon
Gooberman
I just downloaded it made shortcut and added -smp CPU usage was at
100 maybe i'll drop that to like 90 or something
Rocko
I wish I could participate, but my folding power is currently preoccupied! :(
It's not much, but I would like to donate a copy of Crysis 1 to the prize pool. It's not much, but I really like seeing people starting to fold. :good:
voyagerfan99
Thanks for the donation. I'll add you to the prize pool :good: I take it it's a PC copy?
CrayonMuncher
ScottALot what are you using to fold btw, your stats are way higher than everyone elses, im talking both your overall stats and your stats since we started this marathone.
Gooberman
Wish i could have some dedicated stuff lol I ran SMP till 100% finished but received no points :/ then the next one ran and when i went to bed it crashed idk why if i'm on the computer it won't but if i get off it crashes
voyagerfan99
You'll receive the points. It just takes a little while. And Extreme Overclocking only updates every 24 hours I believe.
Gooberman
Q: How often are the EOC Folding stats updated?
A: Every 3 hours, starting at 12 midnight central time (GMT -6). The text in the upper left corner displays general info about processing times. NOTE: The time does shift by an hour during daylight savings. Stanford only updates their data files every 3 hours, so don't ask if I can update it hourly.
found it
jonnyp11
1%, yeah, i had to delete the info and all and reconfigure the non-graphical one to use the smaller packs cuz the others wouldn't have finished for a year.
mihir
Mine does not seem to be making any progress. My CPU usage is high upto 66% and I have four instances of the FAH running still it has been the same for the past 15 minutes.
