Post A Pic Of Your Pc Here :)
Doesnt have to be impossible, these are basic benches on just FPS on the cards but they may be using less powerfull hardware. Its not just the card but also what the card works together with.
Maybe but i think he play at 1280X720 on ultra setting. It is impossible to running around 120 FPS at maxed everything. He can running Ultra setting and maxed res, but still that is impossible to running over 120 with 2 AMD 6990. Unless he can make video of Crysis 2 on YouTube.
Also, i already provide that AMD 6990 CrossFire can not running around 120 FPS as i had post link.
Here's a quick side shot of my current build, forgot to include this before.
Was waiting for that for a while, how do the eATX mobo compare to normal ATX ones?
I see both just have an inch of difference on the side, 800D with air cooling would look like a hollow machine :o in my build.
All computers are different, don't rely just on benchmarks.
And those are at 2560x1600. That's an insane resolution and probably not what he's playing at. And he never said if it was an average or he has hit 120FPS, which is entirely possible.
Making a video will always lower the FPS. it has to record it at w/e reso he plays , we could also just take his word for it. I believe him, its not impossible as I said.
Unless he have monitor 720p or 1080p. I still don't believe that. He might running Crysis 2 Ultra setting at DX 9. DX11 using a lot of graphics.
DX9 or DX11 doesnt matter, its ultra who cares lol.
He can using video camera to record at monitor with Benchmark Crysis 2.
So basically he has to imitate the thing what LinusTechTips does on youtube? I can see that. But why do you want proof?
Old and new side by side. :)
Oh yeah, and I don't need a mirror, I can just use the door on my case. :D
slipx44 said:
if you like I can post a few pic of the inside of my pc. And i have a red led fan, and the red led's in the front
Yes please! Would be interested to see it!
Yeah sorry about posting so late. I didn't realize I have this picture until I checked my Photobucket account. And then I just forgot to post it up.
eATX is a little longer but I guess it just fills the space a little more. It was a problem for me because if you see in the picture, the 24-pin atx connector on the motherboard is led to the side, not like all other standard motherboards. Since the motherboard is eATX then I couldn't use the holes next to the motherboard to run the 24-pin connector. I had to route it behind the reservoir.
Idk why EVGA decided to make that kind of connector but it turned out ok in the end. Kind of a tight fit really but it works fine for now.
If you are going to be using just air cooling then you won't have a problem, you'll have lots of space, more than mine for sure.
really?? I doubt. That is impossible unless you show me a link of proof that play at 120 FPS. Also shown that you installed high res, patch 1.9 and DX 11 patch.
Im not saying that it will average 120fps. But what I am saying is that my pc can run all those settings and not break a sweat. Hell The witcher 2 is pretty playable with ubersampling enabled. Thats why i spent 3500 on this pc, for that type of performance.
Oh okay. "around 120 FPS" sometime can be mean average 120 FPS. That is why I was kinda doubt and confessed.
