CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor £173.94
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler £25.18
MOBO: Asus P8Z77-V PRO ATX LGA1155 Motherboard £152.12
Ram: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory £64.53
HDD: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive £80.63
Case: Corsair 650D ATX Mid Tower Case £136.38
Graphics card: Nvidea GTX 570 (getting this for my birthday)
Power Supply: XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £99.98
Total: £732.76
Hi this is what I have so far, I want a Gaming PC and i suppose my budget is £800 but preferably around £700. I think i will SLI in the near future, by the way i'm just wondering(noob
) if you SLI graphics card can you use just one monitor?
Also what is the difference between the motherboard i listed and the Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard. I have a perfectly fine optical drive(not the best but fine), i have a good monitor 22" and FullHD and LED. I already have an OS, it is windows 7 ultimate 64bit. I just want the the 16GB ram so that is a defo and i might do some video redering and perhaps some video capturing using camstasia. I'm gonna get the GTX 570 as a gift and i am wondering if i can SLI a GTX 570 and a GTX 580 and what is the difference between the GTX 580/570 OEM and the retail, they are both refurbs i think by OCs?
580 OEM :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-160-OK&groupid=701&catid=1914&subcat=2077
570 OEM :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-162-OK&groupid=701&catid=1914&subcat=2077
I think i might want an SSD but i dont know.
Also i am going to overclock the CPU and should i overclock the GPU? Also because of this should i get a much better cooling system. Should i get liquid cooling or just normal fans? I want everything to stay pretty cool inside.
Total: £732.76
580 OEM :
570 OEM :
