You can't run multiple GPUs without SLI/CF.
Actually the 660 ti is around £150 that is very cheap.
Are there any cheap cards you would recommend because i want to buy the 660 ti which will come out in july but me and my friend are going to play some games over summer such as borderlands 1, portal 2 and WAW zombies. Is there any cheap graphics card that will run that? and will i beable to keep both the graphics card you recommend and the 660 ti together but not SLI for example the 660 ti in the x16 and the one you recommend in the x8 slot then when i buy another 660 ti put those in the x16 and x8 and the one you recommend in the the x4 or should i take it out?
Well, since SLI/CF is the act of running multiple GPUs...
For Nvidia, the cards have to be the same exact ones.
A 5870 or 5770/6770 or 450/550ti should handle those games easily. Should be able to find some cheap on ebay. Then after you get the new one, throw it up on craigslist and it should be sold quick, if you live near a largish city.
The PSU he is looking at should be fine for SLI.For SLI, you will need an 850W PSU. Get the Radeon 7850 as it is comparable performance for cheaper.
The Radeon 6850 or the GTX 550 Ti are around £100 and will play those games. The Radeon 5870s are also very cheap on eBay now. I got mine last week for £100 and it can max out all my games at 1080p with ease.Actually the 660 ti is around £150 that is very cheap.
Yep, as I said, I got my 5870 on eBay for £100 and it maxes out my games at 1080p with no problems.A 5870 or 5770/6770 or 450/550ti should handle those games easily. Should be able to find some cheap on ebay. Then after you get the new one, throw it up on craigslist and it should be sold quick, if you live near a largish city.
Do you want it to be able to run 2x 670's?Hey guys can some one help me im buying a Nvidea GTX 670 GPU
a i5 3570k (going to overclock to 4.5GHz)
LED lights
corsair h100 cpu cooler
gigabyte Z77X UD5H mobo
2tb HHD
128gb i fink SSD
16gb ram
and corsair 650d case, what good moduar psu should i buy that wont explode? Model name please?
Think he's British so it'd be £ and I think he only wants the one 670. The OCZ I recommended would be OK but a modular Corsair or Seasonic or XFX would be better.Do you want it to be able to run 2x 670's?
How much $ do you want to spend?
I knowit'd be £
