netbooks_hate_me
its not the best picture i've taken but ted (the dog) wouldnt stay still
I can't see your picture...
got the All Star today. Needs work definitely. The Valve springs were bent, and the corks were gone. Main Tuning Slide is stuck too. Taking it to the shop next week to get the slide removed and chem cleaned so should be better. Plays well to be in as bad of shape as it is.
All together, I would say not bad for a 90 year old horn.
edit, and false advertisement. Serial number decode for 66838 shows as 1901 so its 111 years old.![]()
It sure is. Cleaned up well too. Valves are loose, well not loose, easily moved. Slide still needs to be pulled, but that is a $20 fix, and two of the leadpipe braces are coming loose, so that is another $30. All together less than $300 out on it.That is in really good condition for 111 years old![]()
It sure is. Cleaned up well too. Valves are loose, well not loose, easily moved. Slide still needs to be pulled, but that is a $20 fix, and two of the leadpipe braces are coming loose, so that is another $30. All together less than $300 out on it.![]()
Trying to copy the angle I took of my car![]()
I took those photos on Tuesday night and I'm guessing you took your photos today, so...
Kinda hard to make a family hatchback to look cool.Not that the Leon is a bad looking car, it's just not as sleek or as stylish as your Subaru.
Might want to try in a good scenery.
Yeah, the background makes quite a bit of a difference.Yeah that'd be better.
