I've seen some nasty machines come in from smokers. Let me tell you, they are not pleasant at all.
LOL Wise guy!hehe, is that the front or the backside?![]()
Take a leaf blower and at maximum speed, put the blower at an angle so the dust just flies out. This is what I usually do and it takes about 3 minutes to do and completely cleans everything.
You mean like a little grille? I just put a piece of wire in front of the fan, threaded through a hole on each side so the foam won't get sucked in. Works fine.haha, don't you need a raster on front of your fan?
Wouldn't really recommend doing it this way to be honest, it's not the safest - you can damage your fans if you hold the leaf blower there too long, so at least immobilise the fans or something before you take a leaf blower to them lol.
Wouldn't recommend using a hoover either, causes too much static, and so does a paintbrush.
Compressed air is usually the best way, just make sure before you spray it that there's no moisture coming out of the can. You don't want that moisture inside your system, otherwise when you next turn your system on you can fry it. :/
This is what I use.
I do have a dryer system on it because moisture and paint don't mix very well.
<snip>
So i made some filters out of my gf's old tights![]()
