*Official* Smiles Benchmark Ranking Thread!
what do you mean results, that pick has the results, do you mean his specs (cpu & speed, ram, that stuffs)?
yeah, just set it in your score like I did in the ranks. That would be easyer for me. cpu-z and name on the screen don't make it easyer :P
If they just add it like in the ranks it would be easy shit, just 1 picture of the scores is enough.
Phenom II 960t x4 unlocked to x6 @ 3.8GHz (4 caused crashing during boot and i didn't want to got to 1.3 vcore as it was marked red so figured that wouldn't be good) RAM is 8GB's of 1333
I love how it is labeled the 1600t, and how in the bios the vcore is set to 1.2800 but it reads as 1.32
nice scores! You are now number 3 in the top all and number 1 in amd top :P!
the program doesn't seem to scale the best, i locked her back down, and set the overclock the 3.2Ghz with a 3.5 turbo (bios had the option so said why not, keep my idle temps down) and locked vcore to 1.2, and i still got a 5.6 sec score
yeah, gonna make it harder...
But I need some good codes for it, to test more then only calc speed.
And it's measured in ticks, so ticks can make a BIG difference! I would think that your non-overclocked cpu got at least 5000 ticks more then the oc one...
I'll look into it. I'll see if there's a way to make the benchmark any longer. This isn't a serious benchmarking application, it's just designed for a bit of fun. ;)
if it wouldn't literally burn a hole through my processor, i wish i could've tried intel burn test with it unlocked and all, i really should'a prime95'd it.
we have to wait, because then it's a whole new app...
But the ticks can make much difference like I said above^^
You should put a textbox in it and print the CPU name, cores and other specs automatically that way you can make it more popular.
