Plenty of times before. Driver updates, Windows reloads. I just want to see if I can find a solution. Otherwise I'll live until I build a new rig or update my GPU.
Sometimes my games freeze up, the audio screeches, artifacts appear, the game crashes, and everything artifacts until I reboot my PC. It's weird. Anyway, done the usual driver update and so on?
I've had it for maybe 6 months. I get random video driver crashes (that can recover) and other video crashes that don't recover and reboot the system.
I had the same issue with my other 750W Antec PSU; that's why I got this one.
Have you tried with just the onboard sound and see what happens?
Would it be bad if your PSU wattage matches the video card usage exactly? I have an Antec 750w continous PSU and a ATI 6950 video card. I saw the list states that crossfired 6950's require 750w. Should I upgrade to a 1000w PSU?
So the chart is the recommended minimum size PSU that you should use with a particular card(s)? Good to know I don't have to buy another PSU . Thanks
Everyone,
I will get around to updating this list again, bit more difficult working full time but I promise that it will get done in the next month
I have a few questions.
HD 6990 Crossfire.....................850W ..........................54A
Isn't the amperage determined by (Watts/Voltage)? If the HD 6990 is 850w, why isn't the amperage 71?
How much headroom should I allow for when buying a power supply?
