OK the Storm Sniper looks like a fairly good case, but I like the NZXT Phantom. It has mesh in front of all the fans so that should be fine for you. Here it is
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068 you can get it in white too if you prefer.
I've actually decided on going with the CM HAF XM. I really like the design, and it seems to have everything I want/need.
A few power supply suggestions for you.
Corsair HX 750 80+ Silver
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Seasonic X650 80+ Gold
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
Either one of those or any other quality PSU in the 650-750W range would be fine.
As a friend suggested, I should be going with a PSU that is at least 1000w. I happen to agree. Given I will be looking of going SLI in the future, I better be safe now, than sorry later. So I need some suggestions for 1000w Modular PSUs...
As for CPU coolers, the CM Hyper 212+ is meant to be pretty good
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 I use the Arctic Cooling Freezer 13 myself, it works fine (even with 4 full height RipJaws-X DIMMs installed)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186039. As you're going for 16GB of RAM viva 4x4GB it may actually be worthwhile picking up an all-in-one liquid cooler such as the Corsair H50 or H70 because then you can use all 4 bays on your motherboard without the heatsink getting in the way. Liquid cooling would give you better overclocks and temperatures too. There's an H70
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181019&Tpk=h70 there are cheaper models too such as the H60
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015&Tpk=h60.
I see you're going for a single 670 now, that's a great choice of graphics card still. Get an EVGA one though.
As for Heatsinks, I don't think I'm going to go for a liquid cool solution, just because I've never had one, and everyone I've talked to says their really more hassle than they're worth. I'll check out the normal heatsinks you mentioned. I think I may have to do some research on these. But thanks for the suggestions!
As for the GPU... a friend of mine actually suggested the ASUS brand, so I'm putting that on the list of options (more expensive, and bulkier, so I dunno!) I think I'm going to do a bit more research on all these different brands/cards.
I was going to suggest the Sabertooth early on but I didn't think you'd want to pay for the extra. It's obviousy a great board with a lot of features. The only thing is taking the shielding off to clean.
Yeah, I looked into the Sabertooth, and it seems legit. A bit more expsnive, but I can afford it. As for cleaning, that is why I am going with a case that has dust filters. You should see the inside of my wife's PC after YEARS of use. Only ever needs an occasional Dust Off! Otherwise, squeaky clean!
Ripjaws aren't as tall as as the tall Vengeance so Ripjaws will work with Hyper 212/others.
As for the RAM, both of the two options I have chosen as possibilities are low profile, so both will work just fine. I am going to do a bit more research on them before I decide.
EDIT:
This gets my vote.
Seasonic built.
7 yr warranty.
Will run closer to 50% load than 650w.
Enough for a second 670 if you later on decide to.
The graphics will be correct whether its fan up or fan down.
Nice cables. Modular so you only use the ones you need.
Net is only about $100.(NE)
Again, as I said above... I'm going to want to go with a 1000w Fully Modular PSU.
A couple cases. Black/white/ one of them has military green.
If you find a case you really like but it needs filters, they are available.
Corsair Special Edition White Graphite Series 600T Steel / Plastic ATX Mid Tower Computer Case
Corsair Vengeance Series C70 Arctic White Steel ATX Mid Tower Computer Case
Doesn't look like either of these two cases have dust screens/filters built in... This is why I'm almost certain I'm going to go with the CM HAF XM. Thank you both for the suggestions though!
Really, I just need to select the right PSU and Heatsink now... and do a bit more research on the specs that I have a couple of options for.
