Basically, I need help with a MILD overclock (4.2 - 4.4)on my new rig
I did look around and read some other post but still a little confused - So please dont say i didnt do my homework before coming here and asking for help
After all, we all did ended up being helped by others when you first started overclocking and ended up being good at it - SO PLEASE, don't let the chain of love end with you
I've uploaded a screenshot to make it easier to explain - Im not going to OC my ram, just the CPU
again, all i am seeking its 4.2 to 4.4 OC
which way its better?
leave everything as default and just change the Turbo ratio to 4.2?
i did that before and ran some test and noticed that my vcore volt goes from .972v-1.129 ish (1601MHz-4201MHz) (31c - 62c temp) which is not bad right?
the other method which i havent tried yet - cuz i dont know how is
have a permanent OC speed of either 4.2 to 4.4 .... could you tell me what to change from those chart of my screenshot? - do i have to like set to vcore volt to 1.116v and set 3.5, run prime95 for 2 hours and if pass, same volt with 3.6 and so on until it fails and just add 0.001 volt? and do that all the way till 4.4?
again, i dont know which one to use, the 1600mhz with turbo to 4.4mhz and able to throttle down or have a 4.4 constant... is there a different option too? maybe a constant of 4.0 with option to turbo to 4.5 or etc
also, whats a "off-set voltage" that some people talk about
I dont ever leave my computer running 24/7. I only have it on for like 6 hours a day, lots of websurfing + BF3 game, and the times i dont use it, pc goes to sleep mode within 20 mins, so its not even running straight 6 hours all the time
Thats it guys - if you do find a Guide that matches my need - please post it
PS: Im a licensed Auto technician, if you need any help or have car related questions I'll be glad to help you too
