Yeah, vista really improved it. I like 7 alittle better, it seems 7 is alittle more clean.
I think Vista is very pretty, but I do like 7's new taskbar.
I am on XP 32 bit and i will get 64 bit on a future build.
If you're gonna run 64-bit then just upgrade to 7.
+1. XP 64-bit just isn't worth the hassle.
Well XP is 11 years old, it's time to upgrade. Windows 7 usually has all the drivers anyway.XP x64 has quite a few problems. I have it and sometimes use it, it's not a bad OS if you can find drivers for your hardware and your software works with it.
Some will use it even when it expires and will for years. I know some that still swear by windows 95 OSR2 and Windows 98 2nd edition. They won't change. they will always be there.
Some of us (Older Folks) wasn't born with an "Electronic Pacifier", Like the kids now. I started in 1986 in computers, with a Radio Shack TRS-80 Computer. Then an IBM Compatible xt machine. So, my roots are deep.
Windows XP Pro x64 did have it share of problems, just like any software. But, you work them out. Right now on my new build, which isn't quite done yet till I get my new video card in November due to funds, So, I am running "EVGA 9500 GT" in it tell then. And I am running Windows 8 RP Build 8400 too. Which I find I kind of like. But, I will still get 7 pro x64 (Retail) in December still.
Ohhh... not good. I'm surprised they can even use the modern internet on Windows 98. The internet has changed massively in 14 years.
I still use xp. I think it's the best one ever. Vista is rubbish. I don't know about windows 7.
Yeah, you know about that. Because you were already 1 year when it started
Well, i have 7 iso i will see if i will burn it or no... maybe dual boot...If you're gonna run 64-bit then just upgrade to 7.
