what motherboard did you choose?
Which CPU are you going for? That board will only work with a 3820, a 3930K or a 3960X.
No the GA-Z77X-UD5H won't work with a 3930K, but it will work with a 3770K.
3770K is socket 1155
3930K is socket 2011
They require different boards.
Correct, it depends on the motherboard/chipset.Oh, also I totally forgot to ask for what kind of channels I should go for the RAM, dual, triple or quad ? I don't really understand from the internet which one does a better a job ... Point me in the good direction please
EDIT: I think it has to be Quadruple, 4 x 4, as it depends on the motherboard.
