Virssagòn
without turning anything off i ran it again after unlocking my 2 cores and it seems to scale perfectly, went from 2100 to 3176 and 2060 to 2070 which are close enough to sum up to the background tasks which i didn't turn off, avast, steam, origin, msi afterburner, pretty much it.
total is like 5236 or something like that, i did submit it to you both times i ran it, locked and unlocked.
Which one did you send last?
The same internal ip in the same external ip will be overwritten. (In other words, the submit score on the same pc will be replaced)
Did you oc it at all?
Nice scores btw.
