I was worried about that silver component above my graphic card (sorry don't know how it's called...) and I think it will touch the RAM sticks if it is too long. I can gain a few centimeters by changing the placement of the RAM sticks but it won't go further than about 23cm I think.
The ruler is about 22cm long and the card is about 1.5cm in height...
I would get a 7870 instead, a bit higher price, quite a big performance increase. The 7870 Ghz edition is a r9 270x except it has a different name. You can probably get one cheaper than the r9 270x so I would get one. Also if you don't mind used/refurbished stuff you can get a 7950 for $190 on ebay.
So I'm ordering:
_Carte graphique Vtx3D Vx7850 2GBD5-2DHX X-edition - Radeon Hd7850 - 2048 Mo - Pci-express
_Corsair Cx600M - 600W - 80+ Bronze
Any objections?![]()
It's good stuff yo, go ahead and order. :good:![]()
Ordered, if I can it'll be set up in the next week. If I can't, it'll be the week after![]()
Nice. Pleased you finally went and bought it.![]()
