*Official* Post Your Pictures Thread
The only advantage the D3200 has is more MP. But if you don't have top notch lens it is completely useless as your camera won't be able to get that photo definition. Even 16MP for the D5100 is too much, I am probably using about 10MP at max :). The rest is just making the file bigger :P
Well going by the website you posted a link to, the D3200 is lighter and has more options for video. So if you're into video then the D3200 is probably better.
Both of them have their ups and donws but I chose the D3200.
I don't want to alarm you but... Dude you're driving on the wrong side of the road :P
Nah, he's driving on the correct side of the road. ;) :P
I like the second shot Perko. Real sense of speed there. :good:
What video options?
To be honest, the weight isn't a problem, the D40 was actually too small, I like how the D5100 being bigger feels (no we're not talking about boobs...). And we're talking about 50g mate ;).
Notice how only the English or English colonies drive on this side of the road ;)
What video options?
The website you linked to says that apparently the D5100 cannot record in 720p 60fps, which is great if you want to slow footage down. I know the D3200 can record in this format though. If you don't care about slowing things down, then obviously it's not a problem.
I'm not saying that one is better than the other, I'm just pointing out the differences, as you are too. :) They are both great cameras! :D
Yup. ;)
Went out tonight and did some more night photography. I tried shooting with an ISO 1600 but there was just too much noise but 800 seems almost perfectly clear.
Caught a plane going across the stary sky:
Still have yet to use the autofocus with this camera. Doing it all by eye.
First one is great! Did you use a tripod? If you use a tripod, you can use a much lower ISO. I've done some shots of the road like that and I've used 30 second exposures and ISO 200 with a tripod and they've come out well.
I tried to do a shot of the stars last night, it came out alright.
I'm going to take some shots of fireworks tonight, so watch this space for those. :)
There is no way you will use autofocus for star shots. This one was pretty good, almost perfect in terms of focus :).
Try to shoot at ISO400 or ISO200 with exposures up to 30sec at 18mm. Keep in mind that at high zooms (higher than 50mm I think) you'll start seeing the movement of the Earth on the stars (which isn't a bad thing depending on what you want to do :) ).
Yea I know, which is why I am going to invest in a new telescope with a tracking motor and get a mount so I can use it as a lens :)
And no, in the first picture I didnt actually use a tripod. I sat the camera down on the concrete railing of the bridge :D But in all the other pictures I used a tripod. There is no way I could keep a camera still for 30 seconds. Iv learned that about 1/50 is as slow as I can go holding the camera to not get blur and I dont have the VR lenses.
Bonfire Night Celebrations - Wymondham Rugby Club public fireworks display. Bonfire Night isn't actually until the 5th but the Rugby Club always hold their displays on the first Friday in November.
I shot all of these handheld with the 55-300 VR DX. Yes, I know, I should have used a tripod, but my tripod was too short! (I watched from my back garden :D ). I used the bulb mode with these photos so that I could choose the precise shutter speed I needed. They came out well I think.
VR on, but manually focused to infinity. All taken at 55mm, which is a good focal length to use for these fireworks I found, but next year I may use something a little wider. Perhaps the 18-55 at 40mm or so.
Oh, and a shot of my cat which I took this morning, also with the 55-300 - I'm finding I'm using this lens a lot at the moment. I'll be using it tomorrow too when I go to the zoo.
Yea iv been liking my 55-200 myself. I was comparing the 300 to mine and while mine doesnt have vr, it said that i can pretty much achieve the same distance by cropping. It also said the 55-200mm was cleaner through alot of the focal range compared to the 55-300mm. But yours looks just as clean as mine, although you do have a better camera too.
Ehhh. I REALLY wanted this shot soooo bad I had to walk 3 miles round trip in the freezing cold to get it. However, because of the cold I kinda rushed it and it didnt turn out that well. :mad:
30 seconds, f/22, ISO 400 and alot of post noise reduction.
The reason I wanted to try shooting at f/22 as opposed to the 3.6 Iv been shooting at is because I wanted to see how it would turn out. Figured it would help keep the highlights from blowing up but all around it wasnt a good choice. I should have taken another shot at f/3.6 but it was too cold.
To be really honest, there's not a lot of difference between 200mm and 300mm anyway in terms of focal length. All of those shots you saw of the fireworks were shot at 55mm and the last one of the cat was shot at 165mm. The 300mm just gives a tiny bit of extra reach in some situations, but it's not a huge difference.
There's not a lot of difference in terms of image quality between the D3100 and the D3200 either, but it is my understanding that the 55-300 f/4.0-5.6 which I use is a slightly higher quality lens than the 55-200 f/40-5.6. It's got 'ED glass' in it which can reduce chromatic aberration (read about it here http://www.nikon.com/products/sportoptics/how_to/guide/fieldscopes/choosing/choosing_03.htm) and I think the thread is bigger too (not sure if this is a major sign that it's a better quality lens though). I think your 55-200 is a 52mm thread, same as the kit lens, but my 55-300 is a 58mm, so there's more glass at least. They both have the same relatively same aperture range though.
I don't think the 55-200 will be any cleaner than the 55-300 throughout the focal range, but it all comes down to post processing (if you edit your images). The 55-300 produces some nice images and I'm sure the 55-200 does too.
It looks fine to me. How much noise reduction did you do though? at ISO 400 and 30 seconds you should have probably been alright. I took my first long exposure of a dual-carriageway road at ISO 400 and had a 30 second exposure, but I shot it at f/13. Not sure if the different aperture may have made a difference or not, but I didn't need to do any noise reduction and the shot came out quite well: http://www.flickr.com/photos/jasonbrown2013/8347376750/in/set-72157632572902319
I did this one in August at twilight because the light was a bit nicer. Shot at ISO 200, 30 second exposure and used f/10 (well, to tell the truth, I used Shutter Priority and it set for the aperture for me. ;) ). Didn't need to do any noise reduction on this.
So, I've found using Shutter Priority and setting the shutter speed to 30 seconds will help. Apertures in the f/10-15 range have worked for me, so maybe try that next time?
Did you increase the exposure compensation in post production at all. Because if you bring it up several stops in post production then you may get some noise creep in. When I do these shots, I always use live view and set the exposure compensation to roughly what it needs to be on the camera to avoid having to increase or decrease it too much in Lightroom.
Hope that kind of helps... :)
Why did you use noise reduction at ISO 400? I would have widened the aperture and lowered the ISO to 100-200.
Yeah as you can see from my example, a wider aperture and a lower ISO works nicely (f/10-15 and ISO 200) and you don't need to do any noise reduction. :)
Oh I did though. I dont have the original file anymore. But because I was right under a light as I shot it that was where most of the noise was. It was really grainy along the skyline.
