Okay, I'll see when I have time.Calin i have removed those pictures,They're way too big please re-size them to something more suitable like 1024x800.
It's pretty nice, but if you were to pick up this PSU-
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256084
It comes with an ATX conversion bracket. You could dramatically increase the tidiness of the cables and also the SFX design would give you more space/clearance inside the case which would make things run cooler. The 24 pin connector is designed for mini ITX use so its very short. And then of course its modular, on top of that it's an 80+ gold so more power efficient. It's 44w on a single 12v rail, which is more than enough to handle a 4670k and gtx 760. Both of those are full load would only pull 300w, if that....and I'm talking furmark and prime95 going at the same time.....gaming will never draw that much.
Just a thought if you wanted to do something about it. The PSU is pretty expensive, but IMO it's worth it for a mini ITX build. I've had one, and I subjected it to an H55/I5 750 at 3.6ghz and a gtx 470, both a which draw waaaaayy more power than a 4670k and 760. Handled it like a champ.
Nice PC Mike! Looks very small and compact indeed.New mini itx build.
Not had a pc since early last year so this is like going back into Narnia lol
Cable management is the best i can do with my crap skills and the limited space, the case itself is gorgeous and a lot smaller than i anticipated. Not bad at all. If all goes well with my application for the army i should be able to lug this with me into phase 2 (Obviously i wont have enough time for games in phase 1 lol)
Fixed em
Fixed em
If you say so lol
You need to invest in a new camera or some better lighting.Fixed em
It's an iphone 3. Ill take more photos tomorrow, with lighting.You need to invest in a new camera or some better lighting.
We can only see blue lights and the outline of the case.
They're not missing, they're just transparentWhy are you missing drive bay covers, Calin?
