Had to install Windows 7 on a Fujitsu MX130 S2 server today, thought I'd run BH
Seems very low, but then again, it's an underclocked 8350
These are the systems I'll be testing after exams:
Got them here already, wish me luck with those reviews !
Nice man, just make sure you give it epic cooling and volts!!! I wanna see a fire!
I wouldve expected higher from that turbo!
it will, this is just my 24/7 overclock, problem for a higher overclock 24/7 is the corsair h75
You have it in push pull fan installation?
Make sure Qfan is disabled in the bios or connect the CPU fans to a direct 12V source (e.g. molex to fan converter) to ensure they're at max and see what you get for temps that way. Also putting good quality TIM on every so often helps.
I have a 420 mm (10 cm thick) and a 240mm rad on my CPU so i can run it at 5GHz less than 15oC delta. But boy, does it warm up my study!
Yes its push pull, and when I run benchmarks or stresstest the fans are running at 100%
At the moment the TIM what came with the cooler its on it, normally a use cooler master IC Essential E2
Yeah well do yourself a favour, get some Arctic Silver 5 and replace that TIM. I have seen up to 10oC drop doing so...
