The Coolermaster Hyper 212 Evo: 249kr would be ideal, but it's only 0.8cm shorter than the case is wide, so I wouldn't try it.
The next best value CPU cooler in Denmark is the Coolermaster Hyper TX3: 175kr
I would take the chance with the 212 Evo. I doubt the side panels and motherboard offset is less than 1cm. The TX3 is only ~14cm, so it'll 100% fit.
It's quiet as well - and performs miles better than the one included.
I've used it in a few builds and it's pretty good. You won't find a better alternative unless you go double the price.
I wouldn't take the chance with the 212 Evo.
Not bad either, but I think it's 16cm tall. Taller than the Hyper 212 Evo by 0.1cm
Dimensioner (B x D x H): 9.3 cm x 13.9 cm x 16 cm
The fan on it is 12 x 12 x 2.5cm, so I doubt it's only 13.9cm tall. Good cooler though.
But I assume you aren't overclocking your A10-5800K, considering your low-end MSI motherboard. The TX3 would be fine then.
Oh, and in the previous post I meant:
The TX3 is more than enough, especially if you're not over overclocking.
The tx3 supports fm2 motherboards/processors.
http://www.coolermaster.com/cooling/hyper-series/hyper-tx3/
That part I believe is for Intel cpu's not AMD. If you are using that, then you are most likely gonna have issues.
To attach to AMD it needs to look like this.
The cooler comes with both types of attaching hardware.
