goranpaa
So Don't you thinks i should let this card go coz
1. Its costlier than what i planned to spend on GRPAHICS
2. It will make me buy a new power supply, thus costing me even more!
Can u please suggest some card that will work well with my current powersupply?
That depends? But you your options for a decent caard with will be very limited with you present powersupply. The cards will be narrowed down to the GTX 750 TI and the Radeon HD 7770 pretty much.
Yes, if you want good over all graphics and game performance? The video card will be one of the more exspensive posts for a pc when upgrading.
2. That is unfortunatly often the case when the manufacterer of the pc goes cheap on the powersupplys Wattage. Wich is a very common thing with prebuild pc's.
