*STABLE* Black Hole Benchmark
Yeah, meant the G3258. 40C with stock cooler is pretty chill - regardless of OC. I assume it's on load?
Oh yes Jiniix that was when it was OC running Blackhole, when it`s at stock on idle or just light use like photo browsing etc, it sits between 28 & 32 c
I think for £50 it is an absolute bargain, I would recommend it to anyone looking for a budget build.
I only have one system left on ivybridge when I upgrade that one it will certainly be replaced with another G3258 base.
did pull a oldie from the shell, still a good cpu, when it gets a bit colder try if and how much it will go over 5.0ghz.
I just got a Hyper 221 Plus, should be able to OC my Pentium up to 4.4 Ive heard.
ill run this ASAP
CPU upgrade done, however its still very inconsistent shutting down, will OC tomorrow and post new result, dont expect too much.
The board is a P9X79, X99 will be running 5xxx chips and DDR4 ram.
4.2Ghz, DDR3 1600 CL8 settings
Great to see my bench up and running again ;) Great scores Mr. Brown! Is this machine for personal use or is this build for a friend/customer?
Hey Rob, didn't recognise you with your new username! ;)
This was a PC I put together for a customer last week. It's for running Autodesk software such as AutoCAD. You can see some photos and the specs here: Post A Pic Of Your Pc Here :)
My main machine is still the one in my signature. The only thing that's changed is that it is now running Windows 10 Pro, not 8.1 Pro. :)
The good old sandy bridge is still inside your rig ;) I had times with my 2600K which I'll never forget.
Lol 'times I'll never forget with my 2600K', classic. Is it like an ex girlfriend or something? ;)
Anyway, yeah my three year build/four year old CPU is still going strong! I'm finding that the software released today that I use isn't any more demanding (in fact it is often less demanding) than the software I was using in 2012 when I built this PC, so I don't foresee a major upgrade for a long time yet - especially since I don't play games so there's no need to keep upgrading my GPU (which is probably already overkill for what I use it for!)
Maybe one day I'll put it in a new case and get a modular power supply (I used a Corsair RM650 for the i7 4790K build - 80+ Plus Gold and fully modular for £85, what a good deal!) but that probably won't be for a few years yet. ;)
