Unfortunately it didn't work.
Well, it was worth a shot. Thanks for the suggestion.
Yeah kind of thought it was a long shot, thanks for the follow up
Press search, wait a second or two for it to pop up, type calc, wait multiple seconds for it to show a calc app, then open, which since the new metro version now pops up first, also takes like 2-3 seconds to open. This same task took like 2 seconds total in previous Windows versions.
You might find it more convenient to use Win+R
I downloaded 10 and it took 3 hours, if my very poor internet connection were to drop out in that time I would have had to do it all over again!
Yes a clean install removes all your data, but it also removes every trace of your previous OS. Lots of people have issues after performing an OS upgrade, so a clean install is recommended. Besides, you should absolutely back up your data before doing an upgrade just in case.As far as I understand it there is no need to clean install as you may loose everything if you want to go back unless you backup everything which they say you don't need to. I'm not aware that you have an option to download to a disc drive or that you can detach anything with a right click. Whatever you can or cannot do I for one will be sticking with Windows 7.
Apple have nothing to do with Microsoft, I never mentioned Apple. Microsoft are trying to copy the Android system or make it look like Android by referring to certain elements as 'Apps'.
The intent is that no data will be lost, but as with any upgrade, you should always create a backup as sometimes the upgrade doesn't go as planned and can hose your system.But that's just it, they say that you don't need to back up anything as 'all your programmes and files will be preserved' but clearly some are not. I think unless you're a compter wizard there are going to be many issues with it, no matter how many updates, patches and fixes are put out.
I did the upgrade yesterday. Definitely got a nag screen about backups.they have a full backup before proceeding
