The VCR King
Well-Known Member
I pick up on stupid little things, and today I noticed that when I have FPS drops in Fallout 4, my case lights dim then return back to normal. Is my PSU failing?
I just noticed it happening today.Agreed. How long is this going to go on?
This is like the 1823818th issue you've asked us about with your PSU..I just noticed it happening today.
You're going to keep having issues with it until you replace it!This is like the 1823818th issue you've asked us about with your PSU..
Maybe he should use the meat thermometer and make sure things are okay.
That would imply he has a 'beefy' PSU.
It could be chicken when it comes to delivering a good power load!I say it's a porky psu!!!
Don't laugh, do you realize what's at steak?
I think you should get a Corsair CX600M and see how your system runs. Not terribly expensive but it will power your system fine. It sounds like you think it's the PSU and it sounds like you have concerns about your PSU so it might be a good idea to replace it just so that you have piece of mind.I pick up on stupid little things, and today I noticed that when I have FPS drops in Fallout 4, my case lights dim then return back to normal. Is my PSU failing?
Yes. As we've told you many times already.Is my PSU failing?
I'll definitely give it a tryI think you should get a Corsair CX600M and see how your system runs. Not terribly expensive but it will power your system fine. It sounds like you think it's the PSU and it sounds like you have concerns about your PSU so it might be a good idea to replace it just so that you have piece of mind.
And how many times are you gonna say that before you finally buy one?I'll definitely give it a try
about 1823819 times.lmaoAnd how many times are you gonna say that before you finally buy one?
Get one sooner rather than later. I think a lot of people are getting tired of suggesting it!I'll definitely give it a try
