No no no, i know how to do that.If you're using Linux and don't know how to determine your CPU, you probably shouldn't be using Linux...
Huh?No no no, i know how to do that.
I HAVE i Pentium, i dont USE a Pentium.
It's probably some old computer he has sitting in a box in his parents basement.Huh?
No, i JUST HAVE A PENTIUM! IT DOES NOT HAVE A COMPUTER WITH IT, JUST A PENTIUM!!!!!!!!!!It's probably some old computer he has sitting in a box in his parents basement.
What is printed on the cpu?No, i JUST HAVE A PENTIUM! IT DOES NOT HAVE A COMPUTER WITH IT, JUST A PENTIUM!!!!!!!!!!
well, all i can see is "Pentium Cor....." and the rest is of the label is not readable !What is printed on the cpu?
Ah ok, didn't realise you weren't so close. You two were so competitive about Black Hole!He Hello spirit yes its been a while, to long without a good pc, and no still need some upgrades but getting there, but it was fun being here, no not here from robby anymore, we worent that close, only in the beginning when he was starting his blackhole bench mark, i helpt him alot with testing it on my pc and benchmark the program, because i had a i5 4670k at that time engeniring samle ho clocked very good and a 2700k that did 5.2ghz easy so only then i had contact with him.
but anyway hope that i can help some people here.
Yes i had a 4760k Engineering sample (4.6ghz with 1.3v rock stable and benchmark at 4.9ghz with 1.34v, and indeed a 2700k, and 3570k and i7 975 extreme, i had allot of hardware. i built a pc bench the max and then sold it after a while if i get more money back then i payed. no somthing personel set me backAh ok, didn't realise you weren't so close. You two were so competitive about Black Hole!
So you've got an i5 6600K setup now and you had a 4670K and a 2700K before - what happened to the 4670K and the 2700K? Why did you have to downgrade to such an old and low-end system? Did the i5 and the i7 have to go back to Intel or something?
So why did you get from that lot to a Pentium?Yes i had a 4760k Engineering sample (4.6ghz with 1.3v rock stable and benchmark at 4.9ghz with 1.34v, and indeed a 2700k, and 3570k and i7 975 extreme, i had allot of hardware. i built a pc bench the max and then sold it after a while if i get more money back then i payed. no somthing personel set me back
http://hwbot.org/submission/2614808_
sold my pc for a good price wanted to buy another, but had some financial problems then, so no money to buy a decent computerSo why did you get from that lot to a Pentium?
