Okay it took me a bit to get ram, sorry!Obviously all memory sticks are bad even though it said everything was ok with the 1 stick, sometimes that happens. Try reinstalling with known good ram and go from there.
OkayI would run a check disk on your hdd, and dban your hdd to properly format it. Also make sure you have the latest motherboard drives such as the SATA drivers.
just to update,Okay it took me a bit to get ram, sorry!
But i bought 2 sticks of ram and ran both with memtest and they both gave no errors, but stilll my pc wont boot up and reinstalling windows 10 stops with the same error
Okay
Should i find a iso file for a tool?What brand of hard drive is it? Might want to run a drive diagnostic to test it.
Once you tell me what brand drive it is. The brand determines what tool to use.Should i find a iso file for a tool?
