Sounds like you already know what to do then. So why ask us?In Croatia I would probably get 250$
I just wanted to hear other opinion.Sounds like you already know what to do then. So why ask us?
I would like to buy new pc. Opinion about this one? (Ignore case )
Can u reccomend me something?Power supply?
Also, why in the world are you looking at a Pentium line CPU?
4GB of RAM is low for basically everything these days, 8GB would be much better all around.
I only play Cs:Go but I will probably get 8GB
Ok, thanks for help.I don't follow currency conversion and relative costs elsewhere, that's more of @Laquer Head s thing.
But barring that. I would try to go with a budget-ish i5 or at the very least a i3 or some comparable AMD offering that @Darren would know of.
A SeaSonic, Corsair, or EVGA PSU at around 500W should be fine.
Yeah, we've run into this a few times with members from Croatia... I actually am not much help here - so tough to gauge market overseas compared to North America.. hell even just USA---Canadian bucks can be confusing sometimes as the exchange never makes sense.I don't follow currency conversion and relative costs elsewhere, that's more of @Laquer Head s thing.
Proccesor: x4 640
One, where are you getting 939 out of this?X64 tends to go for 60 bucks on ebay (the 939 chipset).
Can u reccomend some budget-ish proccesors which would run without bottleneck?Yeah, we've run into this a few times with members from Croatia... I actually am not much help here - so tough to gauge market overseas compared to North America.. hell even just USA---Canadian bucks can be confusing sometimes as the exchange never makes sense.
the X64 came as both chipsets (ive been shopping for one)One, where are you getting 939 out of this?
Two, you can get 4400+ X2 on 939 for about $10
bottle necking depends on your GPU, but an older i7 (like my intel i7 960) is a good, budget, high powered system. Youll want to buy a better cooler though, the stock one isnt the best. Beware a mobo for that chipset can be pricy... (i got one used on ebay for cheap, but i was lucky)Can u reccomend some budget-ish proccesors which would run without bottleneck?
Gpu will be rx 460bottle necking depends on your GPU, but an older i7 (like my intel i7 960) is a good, budget, high powered system. Youll want to buy a better cooler though, the stock one isnt the best. Beware a mobo for that chipset can be pricy... (i got one used on ebay for cheap, but i was lucky)
Honestly, not really because I have no clue what is available in your country, nor do I know enough about pricing to make a 'budget' recommendation. Easier to be honest and not help, then to give you poor choices that aren't suitable for your situation.. sorry..I can't help on this oneCan u reccomend some budget-ish proccesors which would run without bottleneck?
In Croatia u can find all parts but they are like <20$ expensive, thanks for help.Honestly, not really because I have no clue what is available in your country, nor do I know enough about pricing to make a 'budget' recommendation. Easier to be honest and not help, then to give you poor choices that aren't suitable for your situation.. sorry..I can't help on this one![]()
So are you looking for a socket 1151 cpu or something else?In Croatia u can find all parts but they are like <20$ expensive, thanks for help.![]()
GPU: RX 460 2GB GDDR4So are you looking for a socket 1151 cpu or something else?
What motherboard do you have...or plan to buy? (Asrock H1? or something else?)
