Help pls, how much is worth?
How much $?
  • 200
    Votes: 1 33.3%
  • 250
    Votes: 2 66.7%
  • 300
    Votes: 1 33.3%
  • 275
    Votes: 1 33.3%
  • Total voters
    3
Laquer Head
Well-Known Member
GPU: RX 460 2GB GDDR4
Mobo: H1-10M HDV 1151 soc.
I'm not sure what budget-ish price is for your situation, but I'd say look at a non-K variant of a 6th or 7th gen i5 cpu. I'm hesitant to recommend an i3, as I just don't think they are the right fit.
With the 7th gen of cpus, while your board supports then, it may require a BIOS flash first for it to recognize - but the support is there.
Trbk2601
Would pentium g4560 cause bottleneck? Buy it now and upgrade cpu later?
Laquer Head
Well-Known Member
That seems like a complete waste of money. Why buy a cheap 2 core pentium CPU now, if your still planning to upgrade..
I'd spend the money on a solid 4 core i5 but, only you know your budget.
Trbk2601
Ok, I will try to find i5 or I will buy cheaper gpu, thanks for help
Trbk2601
Not an Intel chip first off, and no don't do this, its shit~
I understand budget is a concern, it is for most people.. but don't do your shopping based on cheap price tag.
I can easily change mobo so if cpu is good I will change mobo to make it fit. I am looking for cpu under 75$
Laquer Head
Well-Known Member
This isn't making sense.. why would you now jump to an old AMD platform? However, I guess if your budget is $75, you have very few options... I'd personally say, save your money up and buy a PC when you can actually afford it instead of buying the cheapest, oldest, crappiest parts - just to build a 'new' PC.
Trbk2601
I need PC for school, I could stay with current one but for couple months it will be worth much less. But also new parts will come ,so... I will talk with my parents and see what to do.
Laquer Head
Well-Known Member
I'd stick with your current laptop.. its not like its gonna devalue hundreds of bucks.. its pretty much where its at for a basic machine..
Save your money for a proper machine - that doesnt mean you need to spend outrageous amount of money, but buying an old $75 cpu now...and then buying a cheap gpu, and bottom of the barrel motherboard is just gonna upset and disappoint you.. trust me!
Trbk2601
Probably you are right, I will write what I will do. Enjoy your day. :)
