Could you please recommend a new PSU? +1 question
Specs are below.
1. I am looking for a 550W - 650W PSU. I am not very familiar with brands, just a few. (Corsair, FSP, Seasonic)
$70 should be enough for one, or around that price. Could you please recommend specific power supplies?
I assume new PSUs have no compatibility issues with older motherboards.
2. A totally unrelated question: one of my front panel USB ports doesn't function. What could be the problem?
Thanks.
No, I wasn't forcing anything into it. It just sort of doesn't identify anything I plug into it. I have the latest drivers installed. Could it be a physical thing?
Laquer Head
Well-Known Member
Anything gold, modular or fully-modular, and with a rebate by seasonic or Corsair.... so many options
As for the USB if its not a driver issue, very well could be that the port has died..header has died...wires ripped out..hard to say. Is there another USB header off the motherboard to try??
beers
Moderator
Could either try plugging it into another header on the motherboard (the front panel usb connector). If it still doesn't work it's probably isolated to the front panel board.
Laquer, I don't have enough experience to know how to troubleshoot, but I don't expect a miracle. I just ask other people.
I rarely had any problems with my PC. The onboard soundcard is crap now, I have to use a USB sound device. But I've never really been bothered enough to check out the USB headers, as the only thing I tinker with in my case is plugging in SATA devices or graphics cards.
Laquer Head
Well-Known Member
Hey man no worries..
on your board look along the bottom, on the ASUS P8H61-MX there should be 2 (blue color with 9-pins , 10th pin is missing) headers.. they say something like 'USB xx' printed underneath the header right on the motherboard.. turn off computer---unplug whichever is in now...and plug it into the other one..reboot.. see if that helps? either way it will fix a problem, or eliminate a possible culprit and help narrow things down further..
If you can do hdd/sata plug in and install a gpu you can 100% do that ^^^^^^^
I am still trying to figure out where things are. The thing is... it's so not important right now, I could just postpone it as a weekend project.
Laquer Head
Well-Known Member
You honestly don't have 2 minutes to take off side panel and unplug 1 header?????:eek:
Only 2 headers.. one is occupied..the other isn't// unplug one plug into other.. (see below circled in yellow)
Laquer Head
Well-Known Member
I'm not mad, just don't get why people think they can remotely burgle my time.
That's right, burgle... as in time burglar! :mad:
