I would say there is an issue with the front panel shorting out or something. If nothing is plugged into the front why is it showing there is? Is this a fresh build? Has it ever worked? Standoffs between motherboard and case in the correct spots? You may have to build motherboard outside the case on a piece of cardboard to see if it acts correctly.
