need help with msi170a
Discussion in 'Motherboards' started by Jardines2788, Jan 15, 2019.
  1. johnb35
    johnb35 Administrator Staff Member
    41,935
    I would say there is an issue with the front panel shorting out or something. If nothing is plugged into the front why is it showing there is? Is this a fresh build? Has it ever worked? Standoffs between motherboard and case in the correct spots? You may have to build motherboard outside the case on a piece of cardboard to see if it acts correctly.
  2. AlienMenace
    AlienMenace Well-Known Member
    1,052
    Like "Cromewell" had said. You must have the HD Audio "Enabled" for the rear panel audio to work. I would use the Advance mode in bios to configure, not the "Easy Mode".
  3. Jardines2788
    Jardines2788 New Member
    14
    it might be something like that i atually didnt plugged it mysel, so maybe the one who did it screwed up, and now i have no clue i guess i Will have to opne it by myself to see if there is something i can do,thank u man that is an idea
    i Will give it a shot, get back to u later
    guys it says hd audio controller enabled,could this be a hardware issue?
    dude that looks like a lot of work but I dont see another way out,thank u I will give it a try to see what happens
  4. AlienMenace
    1,052
  5. Cromewell
    Cromewell Administrator Staff Member
    15,404
    The board is an msi 170a gaming m5. If it's not a driver issue, then the best bet is likely to contact support through https://register.msi.com/service/ocss or their help phone line https://www.msi.com/page/hot-line
  6. Jardines2788
    14
    guys I live in Cuba, msi support is net getting in here
  7. Cromewell
    15,404
    Why not? You can email them all the same. They don't come over and troubleshoot for you. They give you steps to try, then issue an rma so you can get a replacement if that is necessary.
Share This Page
