On my HP8470p running Windows 10, the wi-fi connection would disconnect a few time over the evening. Mostly is when I haven't touch the computer for a while (it is not in sleep mode). But sometimes it drops even when I am in the middle of using the computer.
Any suggestion?
Check your power plan settings. Your WiFi adapters may be set to turn off. Power Options -> Change Plan Settings -> Change Advanced Settings -> Wireless Adapter Settings -> Change to Always On/Maximum Performance if it's not already.On my HP8470p running Windows 10, the wi-fi connection would disconnect a few time over the evening. Mostly is when I haven't touch the computer for a while (it is not in sleep mode). But sometimes it drops even when I am in the middle of using the computer.
Any suggestion?
Nothing had changed. When it drops, I click the disconnect and connect and go right back on line.Have you changed the routers SID to something unique?
If your WI-fi has the same name as others around you your computer will try to connect to the strongest network, that if its not yours, the authentication fails and it will revert back to your wi-fi...
So changing the SID is Nr:1 when you set up a WI-fi router..
I have it set o Max. but it still happens.Check your power plan settings. Your WiFi adapters may be set to turn off. Power Options -> Change Plan Settings -> Change Advanced Settings -> Wireless Adapter Settings -> Change to Always On/Maximum Performance if it's not already.
Consumer grade networking in 3 sentence fragments.Single host, tshoot nic.
Multiple hosts, tshoot ap/router
Multiple hosts when also wired, router/upstream
I´m surprised that both I and others has forgot to ask you to UPDATE the routers firmware (thee is usually a setting in your router for doing that) There has been a lot of vulnerabilities in many routers lately.. An update might fix any issues in that area..
If the wi-fi faults only on your computer, check your DNS-settings..
Make them use your router as DNS-server (I assume you have DNS-forwarding in your router)
Your router should have your ISP´s DNS servers (comes automatically with DHCP in your router)
Your computer should have your router as DNS-server... (should come automatically via DHCP from your router..)
In your routers settings, make sure your router gives your computer the same IP-adress over and over again..
(It like a fixed IP-adress but from your router)
Make sure your computer uses the correct basic-drivers:
-if its a INTEL-computer download HERE!
-If the computer is AMD-based download HERE!
That usually corrects faulty drivers if you tried stuff like Driverbooster and other who install "almost" correct drivers or if a driver has gone corrupt (Not uncommon if you always use your computer as an admin..)
What? I'm not sure where authentication comes in, for the second part, do you mean like stale DNS records? I agree it's very likely not DNS though.It either will fail to authenticate with the network and not work due to DNS resolution failure or have an IP mismatch or conflict.
My point being DNS issues wouldn't look like this at all. The IP conflict wasn't in relation to DNS, just saying that even if it was that issue it also wouldn't look like this.What? I'm not sure where authentication comes in, for the second part, do you mean like stale DNS records? I agree it's very likely not DNS though.
Ah, the wording really confused meMy point being DNS issues wouldn't look like this at all. The IP conflict wasn't in relation to DNS, just saying that even if it was that issue it also wouldn't look like this.
9 hours into my shift I'm kinda getting some wires pulled loose.Ah, the wording really confused me
I am almost convinced that the problem is the modem/router. Every now an then I have to reboot the modem/router. It maybe one of those flutes that that occurred and came back on, but the machine was discounted.
I use the same machine in my son's WiFi, as well as working in coffee shops, without problem.
