ryzen 7-2700x vs 7-3700x
lostsoul62
In price there is a 25% difference but not a 25% increase in performance. So wouldn't the ryzen 7-2700x be a better bang for the buck?
johnb35
Administrator
Get the 2700x, as you said, there is really no increase in performance. Though 3700x is only 65 watts compared to the 105 watt 2700x.
Darren
Moderator
What are you purchasing for?
This.
There's a very good chance both are way overkill for what you do.
This is just flat wrong?
https://cpu.userbenchmark.com/Compare/AMD-Ryzen-7-3700X-vs-AMD-Ryzen-7-2700X/4043vs3958
Sure it's not a night and day difference but saying they're the same is just incorrect.
johnb35
Administrator
Well if money isn't a concern then yeah, get the 3700x but for a measly 13 percent performance increase for a user that doesn't do anything demanding is probably not worth it. Paying 75-100 bucks more for a 13 percent increase may not be worth it.
Darren
Moderator
Which is why I'm wondering if a 2700X is even worthwhile.
_Kyle_
Well-Known Member
I personally think they are both viable.
The 3700x might actually be worth it with the low power draw. Stick in a low wattage efficient PSU and save some bucks on your power bill.
